Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro 7 project saved as an Executable UNIX file ?!? WTF ?!?
  • Final Cut Pro 7 project saved as an Executable UNIX file ?!? WTF ?!?
    Posted by Benoit Moget on September 27, 2013 at 10:50 am
    Hello!
    I’m getting crazy because as I’m doing my Final cut project, I naturally save it regularly not to lose everything, right ?! But when I wanted to go back on it the next day, I see that the project was saved under “Executable UNIX file” (which only execution is to make me crazy) instead of a normal Final Cut file.
    Does anyone know why it does that? and how can I switch that saving process back to normal please???
    ps: I use Final Cut Pro 7.03 on Mac OS X 10.8.5
    Benoit Moget replied 13 years ago 2 Members · 2 Replies
  • Rafael Amador
    September 28, 2013 at 6:37 am
    That means that your MacOS system needs dome maintenance.
    First, re-launch the Finder.
    If that doesn’t works try repairing Permissions.
    If that doesn’t works, run DiskWarrior or TechTools.
    rafael
  • Benoit Moget
    September 29, 2013 at 8:28 am
    Actually I was sick of having problems so I bought Final Cut Pro X 🙂 But thank you a bunch for your answer!
