Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 7 (probably involves Quicktime X/7pro) to iDVD 16:9 problem
  • Final Cut Pro 7 (probably involves Quicktime X/7pro) to iDVD 16:9 problem
    Posted by Ricardo Guerreiro on November 29, 2009 at 5:51 pm
    Hi, I used Final Cut Pro 6 for about two years, with Tiger then Leopard, and when working with SD footage shot on miniDV camcorder, I used this workflow to export a 16:9 film to burn on a iDVD project (using Quicktime pro 7):
    https://support.apple.com/kb/TS2179
    Everything worked fine until now: 10.6.2 with Quicktime X and Final Cut Pro 7. I export films either on FCP7 as QT movie (Apple pro Res DV-PAL Anamorphic or just DV-PAL 48kHz Anamorphic) or on Compressor for the same formats and doing “Get Info” on the files in Finder they are 720×576, which is what i would expect. Back in Leopard and with FCP6, files exported as this, would show a 4:3 on QT pro 7 and then on Show Movie Props we could change to 1024×576 for the 16:9 ratio which was necessary for iDVD. From then on, QT pro7 would show that movie in 16:9 ratio and iDVD also. What about now with Quicktime X, SL and FCP7?
    Not sure what the problem is. I have QT pro7 also installed so I can do (or try to do) the 16:9 trick in the Show Movie Props window. The thing is that this movies, exported from FCP7 and that show as 720×576 in Get Info of Finder, play as 16:9 in QTX (normal since they are anamorphic) but also in QT pro7, contrary to what happened in Leopard. Opening the Show Movie Props show this:
    https://dl.dropbox.com/u/2789941/qt7.png
    Notice the sizes. 1048,8×576? 1048×576? What the heck is that? Then, if I type 1024 on the scaled size, the display size changes to 1023… if I type 1025, the display size changes to 1024… and needless to say, I have not yet found a solution to this and since I cannot open my FCP project in FCP6 (it is already in FCP7 format), I’m kind of doomed with a DVD deadline to a client. I cannot have iDVD to show the film as 16:9. You might all say “why don’t you go for DVD Studio Pro?”. I’m a one man band. Learned FCP first, now into Motion… Final Cut Studio is six apps and with the rest o life going on I cannot learn them all at the same time. Not yet into DVD SP.
    Any ideas about this mess? Anyone with a similar problem?
    Thanks.
    Steve Eisen replied 16 years, 9 months ago 2 Members · 1 Reply
  • Steve Eisen
    November 30, 2009 at 12:36 am
    DVD SP is as easy as iDVD. Try it. If you are really scared, use FCP 7 share feature and make a DVD.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
