Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 7 – One audio track
  • Final Cut Pro 7 – One audio track
    Posted by Emily Geraghty on August 6, 2013 at 2:28 am
    This is probably a goofy question, new to final cut – but I just edited my entire project and realized that my mono audio is only on track A1, and I want it to play on tracks A1 and A2. The tracks are linked – is there an easy way to get it to play on tracks A1 and A2 or am I screwed? Hope that makes sense. Thanks 🙂
    Kelly Black replied 10 years, 7 months ago 5 Members · 4 Replies
  • Joe Barta iv
    August 6, 2013 at 1:06 pm
    Are the levels on the audio meter showing audio on L and R? If so, then your audio will output equally on tracks 1 and 2 when exporting.
    Bars & Tone
    SALUTE!
  • Simon Modery
    August 6, 2013 at 1:10 pm
    You mean, you only have a signal in A1 and A2 is silent? And that results in the audio only coming out of the left channel? Am I guessing right so far?
    Double click on the audio clip so it opens in the viewer. There, set the Pan-slider to centre. Now the sound from A1 should come out of the left and the right channel.
    Head of Postproduction
    Motherlode
    http://www.simonmodery.com
  • Mark Suszko
    August 6, 2013 at 1:53 pm
    Copy-pasting a duplicate audio track to track 2 can be problematic: it can introduce problems like phase cancellation. Check the single track for center-pan first.
  • Kelly Black
    February 10, 2016 at 4:56 pm
    Ahhhh Thank you!!!! I’ve been trying to figure this out for like an hour!!
