Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro 7 No Timecode Available While Capturing With AJA I/O Express
Tom Meegan replied 12 years ago 3 Members · 11 Replies
Tom Meegan
August 13, 2014 at 6:15 pmI don’t think the DA will help with your problem. I was brainstorming solutions with Shane when I tossed that one out – It solved a problem for me when I was using another AJA product to capture live video, but I don’t think that solution is relevant here.
I suggest you look into the Adrienne Electronics product I linked to above if time code is a necessity.
Alternatively, use the modify time code command after the fact to match the code to the source.
Another solution would be to talk to the EVS operator(s) on location about streaming files to a folder you can share. This is a much more elegant solution, but requires some know how.
If you don’t have success and need more help hit me with an email
tom at wovenpixels dot com
and I’ll try to connect you with an EVS/NLE guru who will be able to look at your whole set up and find the best solution for your needs.
Best,
Tom Meegan
Woven Pixels, LLC
