Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 7 – Media Link
  • Final Cut Pro 7 – Media Link
    Posted by Tim Schwartz on February 21, 2014 at 7:43 pm
    I’m using FCP 7.0.3. I relink media, save the file. When I reopen, it wants me to relink the same media all over again. Frustrating!
    Any ideas on what I’m doing wrong?
    Thanks much.
    Shane Ross replied 12 years, 7 months ago 2 Members · 5 Replies
  • Shane Ross
    February 21, 2014 at 7:56 pm
    What type of media is this? What is the codec? Is it H.264, MP4…some other generic, non-editing codec?
    Shane
    Little Frog Post
  • Tim Schwartz
    February 21, 2014 at 8:00 pm
    Thanks for your prompt response. Variety of media — stills and video. I’m on the rookie side of this world, so not sure what codec I’m using.
  • Shane Ross
    February 21, 2014 at 8:08 pm
    That’s the problem. FCP doesn’t just work with a variety of codecs. FCP requires that video all be converted to Apple editing codecs, like ProRes, DV/NTSC, DVCPRO HD. MP4s won’t work, nor H.264s, or AVIs or whatever. If you want to edit those without converting, you need to use a different editing app. Premiere Pro does this handily.
    Shane
    Little Frog Post
  • Tim Schwartz
    February 21, 2014 at 8:46 pm
    Thanks again for your help.
    When I relink the media, everything seems to work fine. Until, as I said, when I save it and reopen — I then have to relink the same media over again (video, stills).
    How do I convert as you suggest?
    If I go with Premier Pro — can I export/import my current FCP 7.0.3 video into it?
  • Shane Ross
    February 21, 2014 at 8:56 pm
    [Tim Schwartz] “How do I convert as you suggest?”
    Depends on where it all came from. Tapeless masters should be imported via LOG AND TRANSFER, if they are various QT, MP4, AVI…then Compressor or MPEG STREAMCLIP will work. Use PRORES 422 as the compressor.
    If you go with PPro, simple export an XML of your project and import that into Premiere Pro. It will keep the file structure, and bring over the edited sequence as well..
    Shane
    Little Frog Post
