Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro 7 interaction with DVCPRO deck
Posted by Anthony Peltier on May 7, 2012 at 11:10 pmI have a FIREWIRE PANASONIC DVCPRO AJ-D23OH and I’m running it directly in to my NEW MacBook Pro.
Final Cut Pro 7 is running.
The capture is not working.
Can someone please advise me?
Thank you. I appreciate it.
Mitchell Goldman replied 14 years, 4 months ago 3 Members · 11 Replies -
Shane Ross
May 7, 2012 at 11:29 pmDid you choose the DV/NTSC Easy Setup? So that FCP knows what deck to look for?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Shane Ross
May 7, 2012 at 11:46 pmIs this DVCPRO? Or DVCPRO 50? Panasonic did both…and they are slightly different.
Is the tape Standard Def? or is it HDV?
Shane
Little Frog Post
Anthony Peltier
May 7, 2012 at 11:48 pmThe deck is Panasonic AJ-D23OH (i believe this is DVCPRO)
The tape is SD
Shane Ross
May 7, 2012 at 11:57 pmIs the tape you are trying to capture, something shot with a Panasonic DVCPRO camera? I think that there were some minor differences between DVCPRO and DV25.
Shane
Little Frog Post
Anthony Peltier
May 8, 2012 at 12:05 amI cannot get the deck to read on my computer period.
I changed the FIREWIRE cable. I powered the computer off. I powered the deck off. I am directly from the deck to the computer (no daisy chain).
Shane Ross
May 8, 2012 at 12:12 amWonder if the firewire port is fried. That has been known to happen. Try on another computer…try to another firewire port.
Are you using a FW400 to FW800 adapter? Those have been known to cause issues too.
Shane
Little Frog Post
Anthony Peltier
May 8, 2012 at 2:00 amI just have the one MacBook. I switched the 400 to 800 and went to 400 to 400, but had to daisy chain a harddrive to my Macbook. The ports on the deck could be out.
Thanks for your support.
