Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro 7 Hangs on Log and Transfer with certain Red camera footage
  • Final Cut Pro 7 Hangs on Log and Transfer with certain Red camera footage
    Posted by Rob Schulbaum on July 27, 2012 at 5:47 pm
    Every time I try to open one particular Red Camera reel in the Log and Transfer window, FCP7 hangs and I have to force quit it. I’ve tried the reel on three different systems, and it’s the same every time. It’s just the one reel that does this, other reels open up fine.
    The faulty reel opens up fine in Red Cine X Pro. Any ideas what could be wrong and how to fix?
    Running Final Cut Pro 7.03 on a Mac Pro (Snow Leopard) with the latest version of the FCS 3.0 Red Plugin.
    Jerry Hofmann replied 14 years, 2 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    July 28, 2012 at 8:39 pm
    If you can open it in Red Cine, why not just export it from there?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Rob Schulbaum
    July 28, 2012 at 8:50 pm
    I’ve ingested all the other reels as ProRes 422 proxies using the log and transfer dialogue, and our plan was to re-conform from the original RED media using Final Cut.
    If I bring it in through Red Cine X Pro, do you think that will cause problems down the line with our online workflow?
  • Jerry Hofmann
    July 28, 2012 at 11:31 pm
    Try one clip through the proposed workflow.
    Current DVD:
