Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro 7 – Change the speed to the entire timeline/sequence
  • Final Cut Pro 7 – Change the speed to the entire timeline/sequence
    Posted by André Santos on March 14, 2011 at 1:16 pm
    Hi.
    Im a beginner at Final Cut Pro, i know how to change the speed of a clip but,
    today i added in the sequence 2 clips, i added an inicial crossfade and a final clip crossfade… between each two clips, i applied a crossfade too. Then i rendered the crossfades…
    Now, when i select the two clips, and apply the change speed to 3500% for example… Final Cut Pro
    is changing just the first clip, the second one, stays intact in the same place..
    How can i make the entire sequence (40minutes) have +/- 1m30s = +/- 3500% speed change forward ?
    Terry Mikkelsen replied 15 years, 6 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    March 14, 2011 at 3:23 pm
    FCP can only change a single clip at a time. However you can export a sequence of clips as a self contained movie, reimport it, and then apply a speed change to the whole sequence.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Terry Mikkelsen
    March 14, 2011 at 5:37 pm
    Also, if you nest the sequence into another sequence, then you can apply a speed adjustment to the entire sequence.
    Tech-T Productions
    http://www.technical-t.com
