Activity Forums Sony Cameras Final Cut Pro 6.0.4 workflow???
  • Final Cut Pro 6.0.4 workflow???
    Posted by Steve Cohen on August 2, 2008 at 7:04 pm
    I’m trying to change the name of my disk and clips before I bring the clips into Final Cut Pro.
    I can make the changes under the logging tab only, but I am unable to save them.
    I see the dot next to the disk symbol, but when I go to file, Save is grayed out.
    Some one had suggested changing the name of the disk right on the Mac desktop. It won’t let me do that either.
    I know, you’re going to say the dusk is write protected.
    That is what I thought.
    The protection is off (I can see the little red warning in the window), but just to be sure I tried it in both positions and still the same results.
    So as of know I am importing the files from Final Cut and then changing the clip and reel names in there.
    There has to be a better way.
    Thanks;
    Steve Cohen
    Editor
    O2 Media Inc.
    Steve Cohen replied 18 years ago 3 Members · 5 Replies
  • Don Greening
    August 3, 2008 at 3:59 am
    [Steve Cohen] “Some one had suggested changing the name of the disk right on the Mac desktop. It won’t let me do that either. “
    I haven’t worked with XDCAM disks but can you not change the name using the “Get Info” dialogue box? Highlight the disk icon and hit Cmd-I. See if you can change the name there. Just a thought.
    – Don
  • Steve Cohen
    August 3, 2008 at 10:34 am
    OK, I give it a try on Moanday when I get back in the office.
    Steve Cohen
    Editor
    O2 Media Inc.
  • Steve Cohen
    August 4, 2008 at 9:02 pm
    [Don Greening] “I haven’t worked with XDCAM disks but can you not change the name using the “Get Info” dialogue box? Highlight the disk icon and hit Cmd-I. See if you can change the name there. Just a thought.
    No that didn’t work either.
    This is really frustrating.
    Thanks Don.
    Steve Cohen
    Editor
    O2 Media Inc.
  • Jason Lyons
    August 6, 2008 at 7:43 am
    Are you using Sony’s XDCAM transfer?
  • Steve Cohen
    August 6, 2008 at 10:35 am
    Yes I am.
    I’m using the latest version. (The # escapes me right now because I am not in front of it).
    Steve Cohen
    Editor
    O2 Media Inc.
