Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 6 FONT WILL NOT CHANGE
  • Final Cut Pro 6 FONT WILL NOT CHANGE
    Posted by Jason on October 2, 2007 at 5:40 pm
    Hello All,
    I am having trouble changing the font in Final Cut Pro. When I go to the text screen the font is stuck on Lucida Grande.
    We don’t have Apple support since we are a college unless we buy it. 🙁
    But the guy did have me make a new user and it worked fine under the new user….but no luck with mine.
    Any thoughts?
    Thank you all
    Jason replied 18 years, 11 months ago 3 Members · 4 Replies
  • Cameron Preyde
    October 2, 2007 at 6:31 pm
    Well if, when you click on the list of fonts, the only font listed is Lucida Grande, then you might need to install some new ones, or let FCP know where the font list is. Other than that, I’d suggest looking for another version of FCP to dl cause that’s a pretty stinky problem.
  • Jason
    October 3, 2007 at 12:22 pm
    “I’d suggest looking for another version of FCP to dl cause that’s a pretty stinky problem. ”
    I didn’t mean buy FCS we own 18 copies. I meant buy FCS support.
    Still having the problem.
  • David Bogie
    October 3, 2007 at 1:59 pm
    q[jason] ” am having trouble changing the font in Final Cut Pro. When I go to the text screen the font is stuck on Lucida Grande.We don’t have Apple support since we are a college unless we buy it. :(But the guy did have me make a new user and it worked fine under the new user….but no luck with mine.
    You’ve got to be MUCH more explicit; there are twenty different places to modify or select TEXT including the default size for the application interface. If creating a new user account enables the system fonts, you have some simple OS issues to fix.
    Cross posting just wastes everyone’s time. Since you added some information to your thread over on apple.com, you’re starting to get some decent suggestions.
    bogiesan
  • Jason
    October 3, 2007 at 4:39 pm
    I have added a picture. This problem only happens in Final Cut Pro. All other applications are fine. I even re-installed FCP 6.
    I just can’t figure this out.
    It’s weird to me.
    Thank you.
    I didn’t know Creative Cow and Apple used the same forums.
