Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 6 and RAM
  • Final Cut Pro 6 and RAM
    Posted by Jeff Beaumont on June 4, 2008 at 8:16 pm
    I just installed 8 more GB of RAM (for a total of 10GB) on one of our new Mac Pros and though the RAM works fine, Final Cut can’t see it. In the System Settings/Memory & Cache tab it say 2560 MB of RAM available. I thought trashing Preferences would fix it but it didn’t. Usually I use FCP Rescue but that is not working on any of our new Intel Mac Pros (Unexpected Quit on launch) So I guess it is possible that I didn’t trash the correct preferences. user/user name/library/preferences/final cut pro user data
    Any thoughts on what I am doing wrong?
    TIA
    Jeff Beaumont
    Jeremy Garchow replied 18 years, 3 months ago 4 Members · 6 Replies
  • Jeremy Garchow
    June 4, 2008 at 8:42 pm
    [Jeff Beaumont] “Any thoughts on what I am doing wrong? “
    Nothing as FCP can only address 2.5GBs of RAM. Snore. Here’s to 64bits.
    https://docs.info.apple.com/article.html?artnum=93844
  • Kang Stathroy
    June 4, 2008 at 9:39 pm
    That just saved me a bit of cash!
  • Jeff Carpenter
    June 5, 2008 at 2:27 am
    Well, remember Kang, different programs can each use RAM. So if you ever run more than 1 program at a time, having more RAM still helps.
  • Jeff Beaumont
    June 5, 2008 at 5:14 pm
    My reason for the original question was not to report that FCP only uses 2 GB of RAM. I know this isn’t true because that part of the users manual that shows you how to manage RAM and Caches show a screen shot of a system with 8GB of RAM.
    I need to know exactly what preference to trash or what other steps I need to take to make FCP see the new RAM.
  • Jeff Carpenter
    June 5, 2008 at 7:43 pm
    I know this isn’t true…
    Sorry, but it is true:
    That document is talking about Tiger as the reason for the cap since it’s a 32-bit OS. Leopard has improved in that regard, but the situation hasn’t changed because Final Cut Pro is still a 32-bit applictaion. Both the OS and the applicaion must be 64-bit before this can change. It hasn’t happened yet.
  • Jeremy Garchow
    June 6, 2008 at 3:59 am
    [Jeff Carpenter] “Sorry, but it is true:
    Thanks, Jeff for posting that again as apparently it didn’t come through when I posted it.
    Jeremy
