Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 5 interlaced (liney) video
  • Final Cut Pro 5 interlaced (liney) video
    Posted by Deborah White on January 17, 2010 at 2:53 pm
    I’m editing some fast moving footage on Final Cut Pro 5 but when it moves fast the objects get liney (interlaced). Does anyone know how to get rid of this?
    I have tried sequence setting- Field Dominance set to zero
    and
    Video Effects de-interlace
    Both these have made it less pronounced, but it is still liney. Do you have any other suggestions?
    Thanks.
    Deborah White replied 16 years, 8 months ago 2 Members · 2 Replies
  • Rafael Amador
    January 17, 2010 at 4:00 pm
    Hi Devorah,
    Field dominance ZERO, doen’t exist, but sounds great:-)
    When there is no field dominance (better to say no fields) we are talking about Progressive.
    In FC shows as NONE.
    The de-interlacer filter will work in the footage, but you need to set the sequence as NONE at the same time.
    Anyway think that if that looks bad, is an effect of watching interlaced footage in a Progressive monitor (yours Mac monitor).
    If you watch that in a normal TV set that should look OK. If you are working with fast movement pictures, think that these will look smoother interlaced than progressive.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Deborah White
    January 20, 2010 at 12:52 pm
    Thank you very much for your help.
