Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro 5 Capture Now error
  • Final Cut Pro 5 Capture Now error
    Posted by Leonard Nelson on May 12, 2007 at 4:42 pm
    I’ve got a project where I’d like to capture directly from DV cam into my G4. When attempting to test it, I see that the camera is seen by FCP capture. When I click on Capture Now, I get this error.
    Capture Now has reached the end of the tape. All existing footage between the point you started the capture and the end of the tape was captured successfully.
    When I hit the Capture Now button, it starts to capture then flips off withing about 2 seconds. What am I doing wrong???
    Leonard Nelson replied 19 years, 4 months ago 5 Members · 8 Replies
  • 8 Replies
  • David Smith
    May 12, 2007 at 6:22 pm
    Do you have the tape already playing when you hit Capture Now?
  • Leonard Nelson
    May 12, 2007 at 7:28 pm
    Yes. I’ve tried it both ways.
  • Steve Eisen
    May 12, 2007 at 7:34 pm
    Make sure your settings are for non-controllable device.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Leonard Nelson
    May 12, 2007 at 7:46 pm
    Will that mean that the time code generated on the cameera will not be the same as what lays off to the G4?
  • Jeremy Garchow
    May 13, 2007 at 2:35 am
    [Leonard Nelson] “I’ve got a project where I’d like to capture directly from DV cam into my G4”
    You mean directly from camera? You can only do this by changing the device control to non controllable device and you will lose timecode this way.
    Jeremy
  • Leonard Nelson
    May 15, 2007 at 4:31 am
    Jeremy and Steve,
    Thanks for your response. It worked! Unfortunately, my Powerbook stopped after 10 or so minutes saying there was not enough memory. I had over 30 gig available. Any ideas why FCP didn’t see that memory?
    I also ran into an issue with a gif with a client’s logo that had a transparent background. FCP didn’t recognize the transparency and just pushed white. I couldn’t figure out why this happened. When running the same gif in Sony Vegas 7.0 editing softare, transparency worked just fine. Any thoughts about this?
    Again, thank you for your help.
  • Rick Dervisevic
    May 15, 2007 at 3:18 pm
    Hi Leonard
    I’m having the same problem re “not enough memory”. Did you ever figure this out?
    Rick
  • Leonard Nelson
    May 15, 2007 at 4:26 pm
    Not so far. I’m sure it’s an easy fix, though.
