Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro 4.5 Serial Device Control problem
  • Final Cut Pro 4.5 Serial Device Control problem
    Posted by Tabby Sound jeremy on December 5, 2006 at 1:47 am
    Can anyone shed a little light on this problem:
    Final Cut 4.5, Powermac G4 (OSX 10.3.9), Sony UVW-1800 Beta SP Deck….Everything has worked fine for ages, but all of a sudden, the RS-422 Device control preset yields “NO COMMUNICATION” in the Log & Capture, and Edit to tape windows. Cable is fine, Mac Serial port (Griffin G-port) is fine, Deck is fine. The only thing that changed: I upgraded to QT 7.1.3. Is this the culprit, or what?!? Because if it is, i don’t think i can climb back down to QT 6.x very easily…
    I trashed the prefs…no result.
    Any input would be appreciated!
    Jeremy Goldsmith
    Tabby Sound, Ltd
    NYC
    David Smith replied 19 years, 10 months ago 3 Members · 8 Replies
  • 8 Replies
  • John Pale
    December 5, 2006 at 7:52 am
    If you go into the Capture preset, there is a menu to reset your RS-422 port. (you may even see in the summary that the port needs to be reset)
  • David Smith
    December 5, 2006 at 11:24 am
    Sorry, I have to ask…. you checked the remote switch on the 1800? Reseated the cables?
  • Tabby Sound jeremy
    December 5, 2006 at 4:11 pm
    John, thanks for your response…I do not see that option anywhere, perhaps because I do not have a digitizer card (Kona, black magic) that supports serial machine control. I just do Firewire DV capture with a JVC SRVS30 deck, but I often have to output to Beta SP, so I need to control the deck. I’ve always just connected the serial cable to the Griffin G-Port on the back, and to the UVW-1800. It used to work fine. But suddenly there is no communication. A guy at SOS-APPL thought it might have been the QT 7.1.3 upgrade. I dunno..
    Jeremy Goldsmith
    Tabby Sound, Ltd.
    NYC
    December 5, 2006 at 4:25 pm
    << Sorry, I have to ask.... you checked the remote switch on the 1800? Reseated the cables? Good questions, all affirmative. And I've tried 2 different cables, too. I'm stumped.
  • John Pale
    December 5, 2006 at 5:29 pm
    You still need to make sure your device control is set to your G-port and not Firewire. If you have your device control set to rs-422, then the option to reset the port will be there.
  • David Smith
    December 5, 2006 at 10:15 pm
    I’ll test my 1800 tomorrow and get back to you. I upgraded to 7.1.3 and haven’t used the RS-422 since, but I haven’t heard any grumblings about the QT upgrade either.
    Can you test the computer with another deck or the deck with another 422 controller?
    Regards,
    David
    December 6, 2006 at 12:21 am
    Regards,
    David
    Thank you David…i do not have another deck with a 422 interface, but I can confirm that, on the same CPU, Pro Tools does control the 1800 just fine, through the G-port and a MOTU Digital Timepiece. It just seems that FCP isn’t seeing the G-port correctly, even though the settings are right, and Gport shows up in the device control settings window correctly.
    It’s maddening!!
  • David Smith
    December 6, 2006 at 10:53 pm
    Jeremy,
    My RS-422 device control works fine with a UVW-1800 and Quicktime 7.1.3, however my system uses device control via a Kona LH card and not a serial adaptor like you have. If it’s any help, near the bottom of the following linked page is a link to reinstall 6.5 from 7:
    https://www.simnet.is/klipklap/quicktime/
    Regards,
    David
