Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro 3 Way Color Corrector Rendering Issue
  • Final Cut Pro 3 Way Color Corrector Rendering Issue
    Posted by Jonathan Wright on March 28, 2011 at 6:21 am
    I’m working with footage shot on a Canon 7d. After Converting the footage to Apple Pro Res 422 I import it into FCP and everything works fine. A problem I have been having, is when I color correct the footage (and I am guessing the same will happen when I apply any other effects) the footage now has the bright green preview bar above it. I have been making movies this exact same way and have never had this issue before. Usually I can import the footage, drop it on the timeline, edit it however i wanted to, export it, and be done with it. Now, however, I am having to render after every single color correction. I’m new to FCP and could definitely use some help…
    Rafael Amador replied 15 years, 5 months ago 3 Members · 3 Replies
  • Shane Ross
    March 28, 2011 at 10:35 pm
    The BRIGHT GREEN means that you will eventually have to render. It will play back at a lower quality, but you can play it back without any problems.
    WHY NOW? Well, the higher data rate codecs might go bright green if you have a slower processor, not that much RAM, or the drive speed isn’t really fast (faster than firewire)…or a combination of many of those factors.
    But you can work without rendering…render when you are done.
    Shane
  • Jonathan Wright
    April 8, 2011 at 7:06 am
    The thing that confuses me is that I recently worked on a few videos and nothing like this happened. I did everything the same way I am doing now, but I didn’t need to render along the way. I didn’t need to render at all, in fact. I’m working with 8GB of RAM and 70GB free on my hard drive. Any ideas?
    Also, I have to render along the way because I am not able to add transitions unless all the files are rendered
  • Rafael Amador
    April 8, 2011 at 8:59 am
    Have a look to the sequence RT setting.
    [Jonathan Wright] “I didn’t need to render at all, “
    Whenever you apply any Filter or Motion effect, there is rendering.
    Whatever the color you get in FC.
    rafael
    http://www.nagavideo.com
