Final Cut Pro
Is there any way in which an inexperienced user can reset the Sequence settings from PAL to NTSC without intentionally going into Preferences>Easy Setup for instance – or Sequence>Settings ….?
Out of a class of 18 students (19 year olds and not particularly computer literate) nearly half have managed to do this in some way. I setup each student and all the material is imported from PAL miniDV cameras through input settings switched to PAL. On the offending projects the Sequence however has been switched somehow to NTSC and when I try to dump the video projects onto miniDV for storage and for creating copies to send to external examiners I find the recording machine will obviously only accept the sound.
As I am short of time to get these films off the computers, and I don’t have time to do a lot of research and experimentation I have reset the sequence setting to PAL and re-rendered – this still doesn’t produce a recordable copy – I then export as QT and reload the film into iMovie and then export to the recorder. Even for 6-8 minute films this take about an hour and a half. Is there a simpler immediate fix to get the films into a PAl format and is there any way and I can warn students about the dangers of unintentional sequence altering?
PS Two students on the same computer working from the same copy of FCP managed to do it right and wrong in the same term’s work. Neither knows what they did right or wrong – but hey that’s students for you
