Activity › Forums › Apple Final Cut Pro Legacy › final cut pro
final cut pro
Posted by Tim Lindop on September 19, 2010 at 9:13 pmIs there a button I can push that would result with my footage deleted except that used in a selected time-line?
Zane Barker replied 15 years, 11 months ago 4 Members · 6 Replies -
John Fishback
September 20, 2010 at 2:04 amDo you mean you have a certain clip used in a number of sequences and you want to delete all of them except for one?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Rafael Amador
September 20, 2010 at 2:09 am[Tim Lindop] “Is there a button I can push that would result with my footage deleted except that used in a selected time-line?”
Tu put that function in a button, would be very dangerous.
You can use Media Manager to separate the footage you have used in a project/sequence. Then you can delete the rest.
rafael -
Tim Lindop
September 20, 2010 at 4:06 amI realize I might not have been clear. Years ago, before FCP, there was NewTek’s Toaster. To save valuable HD space, when finished with a project, you could have toaster reference every clip in the timeline and automatically delete everything you did not use. This was an automatic function and it would not only delete footage you didn’t use, but any clips you did use would be trimmed to the in and out point established in the timeline. Does FCP have something similar?
John Fishback
September 20, 2010 at 2:26 pmFollow Rafael’s suggest to use Media Manager. If you search this forum you’ll find many discussions about the workflow. Here’s one example.
John
Tim Lindop
September 20, 2010 at 2:40 pmThanks to both you and Rafael. I will start exploring Media Manager!
Zane Barker
September 20, 2010 at 2:46 pmAlso in the future when posing it is best to put something descriptive of your question for the subject. You simply put final cut pro. This whole forum is about final cut pro. Putting something like getting rid of unuded media not only lets people who might be able to help what your question is about. A lot of people will save themselves time and just skip over questions they know they cannot answer well. In addition it REALLY helps those searching the forums if there is a good basic description of what the question will be about in the subject line.
**Hindsight is always 1080p**
