Activity Forums Apple Final Cut Pro Legacy Final Cut Pro
  • Posted by Aboud Orfali on March 19, 2014 at 7:11 am
    Good day;
    I have the following configuration : Apple Mac Pro (12 Cores /2.66 GHz/ 12 GB RAM /Snow Leopard OSX / G Speed es Pro ( Mini SAS connectivity 8TB /RAID 0/AJA KONA 3G Card with Break out Box /Final cut Pro 7/HD Footage).
    The problem :
    – Dropped frames.
    – Lipsing
    Please note that I have another system identical to the previews , in which I do not encounter any of the above mentioned problems.
    Will any one help please .
    Thank you
    Aboud
    Aboud Orfali replied 12 years, 5 months ago 2 Members · 5 Replies
  • Mark Suszko
    March 19, 2014 at 1:25 pm
    If you truly have identical twin systems, what I suggest is trading cables, drives, and other parts between the “good” one and “bad” one, one thing at a time, and seeing what changes.But my guess is going to be either a RAID problem or a video card problem. Start with swapping cables, as that is the easiest and cheapest thing to try first.
  • Aboud Orfali
    March 19, 2014 at 2:13 pm
    Thank you for your reply. I will try this and return to you .
  • Aboud Orfali
    April 6, 2014 at 11:54 am
    Hello again ..
    I have tried replacing different parts from the cables and still getting the same result;in addition i am now having a (lipsing) problem which occurred several times on different locations of the time frame . Any ideas ?? Thank you for all the help & support .
  • Mark Suszko
    April 6, 2014 at 1:49 pm
    Did you swap the video cards yet?
  • Aboud Orfali
    April 7, 2014 at 6:04 am
    Yes I swapped the video cards and all the cables one by one and still get the same result.
    Thank you
