Activity › Forums › Apple Final Cut Pro Legacy › final cut pro
final cut pro
Posted by Enrika Colusso on May 6, 2009 at 9:21 pmI’m trying to export my timeline (75min) to quick time and I keep getting ‘general error’ and fc shuts down.
I have filmed in dvcam Pal and until quite recently have been able to export to quicktime to make dvds of my rough cut.
Could you please let me know what could be the problem?
thanks
Eric Johnson replied 17 years, 4 months ago 3 Members · 5 Replies -
Aaron Neitz
May 6, 2009 at 10:27 pmEnough free space on the drive to export to?? 75mins might be a pretty big file.
If not, delete all your render files and re-render. sometimes you can get a bum render file tucked away in your edit.
Eric Johnson
May 7, 2009 at 12:17 amIf not that, trash your prefs. Digital rebellion has a cool app to help with that….
Enrika Colusso
May 7, 2009 at 12:47 amhi Aaron, thanks for this. I went to delite the rendered files in the folder and there are two folder inside, one is has the rendered files ad another called CONSTANT FRAMES has a liste of files with this names CF-dvc appl-720×4801023303 What is it do I have to delete them as well…
Enrika Colusso
May 7, 2009 at 12:49 amHi Erik, that for you advise, how do you trash the prefs. Sorry I am relative new at this…
Eric Johnson
May 7, 2009 at 5:20 pmdownload this app using this will be much easier than looking for the pref’s.
Though, if you feel like looking, Home/library/preferences/Final Cut Pro User Data/
In the last folder you will find 3 files that look like FCP project files: Final Cut Pro 6.0 Prefs.fcset, Final Cut Pro Obj Cache.fcmch and Final Cut Pro Prof Cache.fcpch.
Delete these. And restart FCP. After FCP is open, empty the trash and reset your FCP settings.
If you download the Digital Rebellion Preference Manager, now is the perfect time to Backup your preferences to make this easier the next time they go bad.
