Activity › Forums › Apple Final Cut Pro › Final Cut Pro 10.8
  • Final Cut Pro 10.8
    Posted by Ben Balser on June 20, 2024 at 6:34 pm
    New in Final Cut Pro 10.8
    Released June 20, 2024
    Final Cut Pro 10.8 includes the following enhancements and bug fixes:
    • Automatically improve the color, color balance, contrast, and brightness of video or still images using the new Enhance Light and Color effect, powered by machine learning.
    • Enable Smooth Slo-Mo to create amazing slow-motion visuals with an AI-enhanced algorithm on Mac models with Apple silicon.
    • Stay organized by renaming color corrections and video effects in the inspector.
    • Drag effects right from the inspector to other clips in the timeline or viewer.
    • Use new filters in the timeline index to quickly identify clips with audio effects, video effects, retiming changes, missing media, or missing effects.
    • Search in the timeline index by reel, scene, camera angle, camera name, custom metadata, or effect name.
    • Search in the timeline index for user-created roles.
    • Search for clips in the browser using new “Starts With” and “Ends With” search criteria.
    • Enable or disable timeline scrolling using a new toolbar button.
    • Improves timeline scrolling behavior during reverse playback.
    • Fixes an issue where captions would sometimes flicker when timeline scrolling is enabled.
    • Fixes an issue where browser items would be appear to be renamed when naming a folder.
    • Fixes an issue that caused disabling the audio roles of a clip to make the video roles appear disabled.
    • Accurately tone-maps HDR video content in 360° view for 360° projects.
    • Fixes an issue that could cause ProRes RAW clips to be displayed incorrectly in the viewer on Intel-based Mac models.
    • Fixes an issue that caused a freeze frame from a log-encoded clip to appear too bright in an HLG timeline.
    • Fixes an issue that caused a disabled Color Board effect to be incorrectly enabled after exporting and reimporting an FCPXML of the timeline.
    • Fixes an issue that caused the Space Designer audio effect to show presets as missing.
    • Fixes an issue that could cause Final Cut Pro to stop responding when rendering with another app active.
    • Fixes an issue that caused switching between the angle viewer and the video scopes to change the angle viewer selection back to “Enable video and audio switching.”
    • Fixes an issue that caused Final Cut Pro to stop responding when both a folder and an enclosed item were selected in the browser.
    • Adds support for sharing 8K ProRes MXF files.
    • Improves support for Canon C2 AVC media.
    • Adds support for Canon XF-AVC 1920×1080 59.94i/50i H.264 25Mbps.
    • Removes support for disc burning.
    • Updates FCPXML to version 1.12.
    Mads Nybo jørgensen replied 2 years, 2 months ago 7 Members · 15 Replies
  • 15 Replies
  • Doug Metz
    June 20, 2024 at 6:43 pm
    Backed up and updating now!
    Honestly, this is far more than I expected from 10.8.
  • Ben Balser
    June 20, 2024 at 8:28 pm
    IMHO, compared to what other NLE “major updates” look like, and what FCPX updates used to look like, I was expecting more. Of the 26 bullet points there, only 10 are new features. But, yeah, they have to get it up to speed for the VisionPro. I don’t think we’ll ever see a proper audio mixer or consolidation function.
  • Doug Metz
    June 20, 2024 at 9:14 pm
    I certainly wouldn’t mind better mixing tools, but I just don’t need a full DAW attached to my NLE. Others might. I could see maybe a different project type with a ‘mix’ icon, where you get a different interface with faders, channel config, sends, etc. If round-tripping wasn’t such a crapshoot, that alone would be a big improvement.
    I still view FCPX in a sort of ‘camera body’ context, where I can build or buy the options I need.
    Project consolidation tools are quite another story – Ol’ #7 had pretty good options that I still miss.
    Another thing that would help a lot would be comprehensive info in the inspector explaining why that stupid yellow triangle is on my timeline icon in the browser.
  • Greg Ball
    June 21, 2024 at 5:28 pm
    Is it safe to update? Or should we wait for 10.8.1?
  • Doug Metz
    June 21, 2024 at 6:26 pm
    I zipped a copy of 10.7.x, and tested a few libraries.
    Only thing I need to get used to is hitting the icon for Color tab on the inspector – I’m used to double-clicking on an adjustment to open the pane, and now that renames the effect.
    Tested a variety of media types, multicam clips, etc. So far, all good! Don’t forget to update Pro Video Codecs. If you need to burn DVDs out of FCP, you’ll want to find a new workflow before updating.
    EDIT: I will note that I’m between projects at the moment. Would’ve waited if I were in the middle of something hot.
  • Ben Balser
    June 21, 2024 at 8:10 pm
    Roxio Toast is still a viable option for optical disk burning. I know a bunch of folks still use them, and FCP’s disc tools were very limited and flimsy anyway.
  • Ben Balser
    June 21, 2024 at 8:13 pm
    Greg Ball, don’t upgrade for a month. Let those of us who think we’re brave, or are just dimwits (such as myself) find the bugs first. LOL!
    But if you wanted to try it out, go to your Applications folder, right-click FCP, and choose Compress File. Then backup any Library you want to test with to a separate drive. Finally, upgrade to 10.8 and knock yourself out (figuratively, literally for some of us). If you run into too many problems, trash FCP 10.8 and your updated Libraries, double-click the zip file of FCP 10.7.1, copy your original 10.7.1 Libraries back, and you’re safe.
  • Jose Munoz
    June 21, 2024 at 10:24 pm
    I use Compressor almost daily for disc stuff. It’s a real shame it’s gone from compressor now. The authoring of ISO’s was a big deal for me. Toast doesn’t feel like a good replacement. I don’t like their compression tools and it’s just going to add one more step to my workflow. I’m not sure why they would remove it.
    Sticking with 10.7 for the foreseeable future.
    June 22, 2024 at 5:37 pm
    Hey Ben,
    I agree, this latest upgrade to FCPX is just underwhelming.
    One long list of fixes, rather than getting in the game.
    Maybe they are saving it for version 11, or maybe not.
    But then, Adobe PPro/Creative Cloud is currently not that different.
    Adobe appears to be busy removing functionality + making claims on our work (which they have now rescinded on – but they did it without consideration to their customers).
    Short version is that in these big companies C-Level and Product Development Management have run out of ideas. And, it is likely that they are running scared of the $1BN+ A.I. companies that want to use 5-legged/12 fingered/4 eyed humans to peddle the next generation of Generative A.I.
    I suspect that with the price of Avid MC dropping, and that Avid is still putting media management first, that we might be pushed back to that – not that I think that Avid is the perfect solution. They are not, but compared to how the current “industry leaders” are behaving, we might be better off…
    Just an opinion.
  • Ben Balser
    June 22, 2024 at 7:41 pm
    FYI, I use Roxio Toast on the rare occasion I need an optical disc and find it easy to use with great quality results.
    Avid is still super expensive, I’d not touch it.
    DaVincie Resolve is the way to go now, very affordable.
    Yes, FCPX has really fallen behind and isn’t getting as much love. Seems every update introduces things specific to other Apple hardware (iPhones/iPads) only. I doubt we’ll see any of the things other NLEs do that Apple doesn’t. Personally, I’m slowly switching things over to Resolve as my work allows me to. And just to be interesting…
    FCPX macOS cost $300 for 10 years of use.
    FCPX iPadOS* cost $490 for 10 years of use.
    Davinci Resolve Studio macOS costs $300 for 10 years of use.
    Davinci Resolve Studio iPad costs $95 for 10 years of use.
    Avid Media Composer* costs $2500.99 for 10 years.
    Premier Pro* costs $2,638.08 for 10 years of use.
    *Based on annual subscription rate for single app.
