Activity Forums Apple Final Cut Pro Legacy Final Cut: PAL to NTSC
  • Final Cut: PAL to NTSC
    Posted by Pat Ford on July 31, 2008 at 6:37 am
    I have some PAL to NTSC conversion to do. An associate tells me that the latest versions of Final Cut can do this conversion natively. (that is without any plug-ins…I know there is a Natterson plug-in.)
    Anyone had any experience with this. I have run through several converters that were supposed to do this but they did a pretty bad job with the frame rate conversion.
    Thanks in advance.
    Pat Ford replied 18 years, 1 month ago 4 Members · 4 Replies
  • Shane Ross
    July 31, 2008 at 7:50 am
    Cinema Tools can do this. FCP cannot, without the Nattressy plugin.
    Shane
  • Sean Oneil
    July 31, 2008 at 8:40 am
    Like Shane said use Cinema Tools. Conform it to 23.98, and edit in a 23.98 sequence. That’s the best method by far.
    Sean
  • Alexander Kallas
    July 31, 2008 at 11:54 am
    Correctly set, Compressor in FCP studio with optical flow technology, (set in the Frame Controls tab of the inspector) will give you the best software conversion.
    This has been described in this forum many times.
    Cheers
    Alexander
  • Pat Ford
    July 31, 2008 at 4:55 pm
    Thanks guys.
    Will relay the information to my associate. Don’t have Final Cut myself.
