Activity Forums Apple Final Cut Pro Legacy Final cut output movie into what file?
  • Final cut output movie into what file?
    Posted by Greg Bloomberg on March 26, 2012 at 5:42 pm
    Hello, I am finalizing several clips at a time, for a feature film.
    I want to be sure I have chosen the right quality, size, formats etc for each quicktime movie. I intend to put each segment back into final cut to make the complete film, have to do this because of space issue.
    This is what I made so far, Dimensions 1280×720
    codecs integer ( little endian) H. 264
    Is this correct or should I have used something else?
    Greg
    Stephen Smith replied 14 years, 5 months ago 2 Members · 1 Reply
  • Stephen Smith
    March 26, 2012 at 6:05 pm
    This is what I would do:
    File, Export, Quicktime Movie. Make sure setting is set to “Current Settings” and that the Make Movie-Self-Contained check box is checked. It will export out a movie in your project settings settings so when you bring it back in it will be the same as you have already been working with.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
