Activity › Forums › Apple Final Cut Pro Legacy › Final Cut noise reduction plug-in
Posted by Thomas Winston on March 4, 2010 at 4:28 pmI’m looking for a noise reduction plug-in for Final Cut. I used one before that worked great that I thought was put out by FXfactory, but I can’t seem to track it down. Any suggestions are much appreciated.
THX!
Thomas
Thomas Winston
EP/DP
Grizzly Creek Films
http://www.grizzlycreekfilms.comRafael Amador replied 16 years, 7 months ago 5 Members · 6 Replies -
Thomas Winston
March 4, 2010 at 6:14 pmSorry if I wasn’t clear, I’m asking about visual noise in the picture, not the sound.
Thomas Winston
EP/DP
Grizzly Creek Films
http://www.grizzlycreekfilms.com -
Colin Mcquillan
March 4, 2010 at 6:22 pmNot all ‘noise’ is audible!
I infer the OP is talking about picture noise.
Colin McQuillan
Vancouver, B.C. -
Colin Mcquillan
March 4, 2010 at 6:38 pmThe version of Core Melt that shipped with ver1 of FX Factory had a plugin called Noise Limiter. Works OK.
The Noise Industries Noise Reduction plugin does a decent job if its just a touch you are after. Anything more and it just blurs the picture beyond use.Nattress has a few decent noise reducers (Chroma, Spatial, and Temporal,) though I have found they only render properly when timeline renders are set to 8-bit only.
Any of them need to be used sparingly and wont completely remove the noise/grain from a shot. Adding a touch of sharpen helps keep the defining lines in check.
Colin McQuillan
Vancouver, B.C. -
Phil Balsdon
March 4, 2010 at 7:38 pmNeat Video is excellent, but you have to pay for it.
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
https://www.steadi-onfilms.com.au/ -
Paul Dickin
March 5, 2010 at 9:29 am[Phil Balsdon] “Neat Video is excellent…”
Hi
Having got by (= struggled) with the various freebie noise reducers I recently bought the Neat Video plug-in – which is magnificent.All the extra gain-up noise disappears, and with appropriate adjustment of the sharpening tool it can minimise some of the wide-aperture lens, enhancing rather than losing edge definition.
Rafael Amador
March 6, 2010 at 12:44 pmWithout hesitation, NeatVideo.
But you need a bit of practice and a good monitor to use it properly.
Rafael
