Activity › Forums › Blackmagic Design › Final Cut must be restarted to play…I use Blackmagic Decklink
  • Final Cut must be restarted to play…I use Blackmagic Decklink
    Posted by Vinnie on October 31, 2007 at 4:35 pm
    ust like the Subject line says I have to restart before I play/capture in Final Cut. Once I have restarted it plays and runs fine…no worries. I know it sounds like a RAM problem but and I was told to run “Memtest” to detect if I have some bad RAM but everything came out good, even in single user mode.
    I don’t know if this is a BlackMagic issue but any suggestions would be more than appreciated because I am stuck!
    Now the tech specs:
    FC Studio 2
    Mac Pro 2 x 3Ghz Dual-Core Intel Xeon
    4GB 667 MHz DDR2 FB-Dimm
    NVIDIA Quadro FX 4500
    Black Magic DeckLink Extreme Capture Card (playing/Capturing SDI)
    Two 700Gb drives plenty of room
    OSX 10.4.10
    Quicktime Pro 7.2
    Kristian Lam replied 18 years, 11 months ago 2 Members · 1 Reply
  • Kristian Lam
    November 1, 2007 at 5:30 am
    What happens when you don’t restart? Can you describe the problem?
    regards
    Kristian Lam
    Blackmagic Design
