Activity Forums Apple Final Cut Pro Legacy Final Cut Multiclip Playback
  • Final Cut Multiclip Playback
    Posted by Ursula Mann on November 13, 2009 at 7:36 am
    I am trying to play back mutliclips simultaneously on Final Cut. Usually I can double-click on the video layer in the sequence and all angles come up in the viewer…if I set the canvas to “open” I can usually watch all angles play back at the same time….
    What’s going on? Id this a software bug or a setting issue? Sometimes the multiclip will show the angles if I double-click but it won’t play them all together. It just freezes and then jumps back to the main angle…?
    Ursula Mann
    Brooklyn, NYC
    Chris Burke replied 16 years, 4 months ago 3 Members · 2 Replies
  • Andy Mees
    November 13, 2009 at 1:03 pm
    make sure you have not rendered the multiclip within the timeline
  • Chris Burke
    May 7, 2010 at 2:13 am
    This is happing to me too! When I try that it wont play it will just stutter. Do you know of any other way to get this to work? Thanks
