Final Cut, Media Manager, Creating Offline, Varied sized source material
Hi Everyone,
Although this is my first post, I have been using the forums for years as reference. However I am on a project that poses an issue that (from my searches) nobody has touched on (Please forgive me if I am missing the obvious).I’ve shot a short film on RED, 5D and 7D (I know, but the 5&7D were suppose to be as back up but the footage has become integral to the film). So I have all my footage converted to ProRes 4444 and set out in my project (I also know 4444 is overkill but for colouring I will hopefully have access to a machine that will handle it with ease). In the meantime I will need to do the edit on my Macbook Pro, thus need to make an offline. However, I have some footage at 1920×1080 (Canon), some at 2240×960 (RED) and some at 4480×1920 (Red for punching in tighter). I want to create an offline in Prores (LT), half the size of the sequence (to 960×411) and half the size of the various footage. So when I link back I will simply double the sequence size to 1920×823 and everything should match up bar a few adjustments (I don’t mind).
However as far as I can work out (but I am no expert!) if I use Media Manager it will compress all my footage to the same size, but that will prevent me from being able to punch in on the Larger red footage, and also prevent me from being able to select what part of the Canon Footage I can select to fit into the wider aspect ratio.
Does anyone know a way around this? Please…………….
Cheers, James (First time poster)
