Activity › Forums › Apple Final Cut Pro Legacy › Final Cut is throwing an error message & not exporting the footage
  • Final Cut is throwing an error message & not exporting the footage
    Posted by Lisa Rudnitsky on September 30, 2014 at 3:06 am
    I can’t seem to export media. It seems as though there is a pause in the system but nothing happens.
    When I try using compressor or export using compressor settings iFinalCut Pro is throwing error “The operation couldn’t be completed (com.apple.compressor.compressorKit.Err or Domain errror -1).
    I need to render out footage and can’t get it to work. Please advise.
    (the only change to my Final Cut/Mac is that it recently had me update the IOS).
    Daniel Waldron replied 11 years, 12 months ago 2 Members · 1 Reply
  • Daniel Waldron
    October 1, 2014 at 3:57 pm
    What did you update your OS to? Final Cut Pro 7 and under are no longer supported by Apple, so updating the OS can be risky business. If it worked fine before the update, that is almost definitely the culprit.
