Activity › Forums › Apple Final Cut Pro Legacy › Final Cut import p2
Final Cut import p2
Posted by David Hueso on September 29, 2009 at 8:59 pmSuch…Wanting to import a P2 card to Final Cut I get the option not..
Which is
File import import p2
I already download the driver from the web and nothing p2…
Is any plugin Final Cut?
My version of Final Cut is 6.0.5Cass Vanini replied 16 years, 7 months ago 4 Members · 10 Replies -
Tom Wolsky
September 29, 2009 at 9:30 pmYou need to use the log and transfer function. You should read the manual about how this is used.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
David Hueso
September 29, 2009 at 9:33 pm -
Tom Wolsky
September 29, 2009 at 9:53 pmThese are two different versions of Final Cut. Note in the first menu Log and Transfer Cmd-Shift-8. The bottom menu is an older version. You might want to run software update to go to 6.0.6, but you should have log and transfer in your version.
All the best,
Tom
Jeremy Garchow
September 29, 2009 at 9:57 pmIn FCP6, it’s log and transfer, in FCP5 (Pre5.1), it’s Import > P2.
Jeremy
David Hueso
September 29, 2009 at 10:01 pmgracias Dave eres muy amable.
y al momento de hacer log and transfer hay compresion?
como trabajo en el final cut con la informacion de la tarjeta sin compresion?
o estoy equivocado?
gracias una vez mas -
Jeremy Garchow
September 29, 2009 at 10:09 pmIt’s the same. All Log and Transfer is doing is combining the video and audio into one Quicktime file.
There’s no recompression, no transcoding. It’s of equal quality for DVCPro HD material.
Jeremy
Cass Vanini
February 23, 2010 at 4:27 pmHey all,
Im importing P2 footage into FCP 6.0.6 easily through the log and transfer tool however Im not able to bring it in with any option other than prores/prores HQIm supposed to farm shots out to animators/designers and they will finish from there.
How am I supposed to bring this stuff in uncompressed? Or better yet, since Ive already cut, how can I upres the converted files to uncompressed?
please help. Any info would be most apprecitated.
-Cass
