Activity Forums Apple Final Cut Pro Legacy Final Cut Hitch
  • Final Cut Hitch
    Posted by Geoff Mckay on August 20, 2011 at 5:04 am
    Hello Everyone,
    I am having some difficulty with Final Cut. I find that when I add a frame hold, or slow a clip down, there is always a vertical jump to my preview just as the “altered” clip ends. It only happens when I preview the sequence, and if I go frame by frame, I don’t suffer the problem. Also, when I output the movie to compressor, it doesn’t show any ill effects. Only when I am actually watching the project in the canvas.
    Also, if I link several “doctored” clips together, only the final one shows the symptom. Any suggestions?
    Geoff
    Geoff Mckay replied 15 years ago 3 Members · 4 Replies
  • David Battistella
    August 20, 2011 at 8:54 pm
    You only are viewing one field in the FCP canvas and viewer windows. The jump is probably the missing field.
    David
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://vimeo.com/battistella
  • Geoff Mckay
    August 20, 2011 at 10:58 pm
    Makes sense. How do I rectify this then? It’s really not possible to edit properly if I can’t preview what my product looks like.
  • Andrew Rendell
    August 21, 2011 at 5:54 pm
    Just wondering, does the jump always happen where you’re going between an unrendered effect and an unmodified shot? If so, it might make a difference if you render the modified shot. Even if it doesn’t “need” to be rendered for playback, there might be something going on that glitches on real time playback (which wouldn’t be there when you output, because going to Compressor would render it all anyway).
  • Geoff Mckay
    August 21, 2011 at 6:45 pm
    Andrew,
    Yeah, it’s funny. It glitches, even after it’s been rendered. There is a slight hesitation as the playhead rolls over the cut between the slow mo, or freeze frame clip, and the unmodified clip.
    For example, I got some underwater footage of a spawning salmon rolling it’s eye backward and making eye contact with the camera. I want to run the clip at full speed until just before this happens, then slow the clip down and finally frame hold on the salmon looking at the camera. My intention is to hold for a second or two, then ramp back up to full speed. Everything seems to work okay until the playhead reaches the full speed clip. It pauses for a fraction of a second, just as the hitch I am talking about happens. I am wondering if it is a RAM problem. I am working with 4 gigs of ram, maybe it’s not enough.
    Geoff
