Activity › Forums › Apple Final Cut Pro Legacy › Final cut Fx
Final cut Fx
Posted by Fredric Lean on January 30, 2011 at 8:50 pmI am looking tutorial on how to do the “vibrating” “scattering” FX in final cut pro.
here’s an exemple
https://www.youtube.com/watch?v=D23ng_Clky8Thanks
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Peter Wiggins replied 15 years, 7 months ago 3 Members · 5 Replies -
Jeff Greenberg
January 30, 2011 at 11:07 pmCan you give a timeline for exactly what you’re trying to do?
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com -
Fredric Lean
January 31, 2011 at 1:31 amThank you Jeff
I am a newbie at FCP so my wording may not be the one typically used to describe the FX. What I am looking for is to get some kind of trembling/vibrating FX of the footage- I saw this FX in some horror films, and sometimes in action sequences.
It is at 53s when the actor is starting to have some weird visualizations. It may have been done thru quick cuts only without a special FX.
here’s another example close :
https://vimeo.com/3114617
FX is at 1.33ms.Is there a good FCP video tutorial online for dummies like me that covers the basics?
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jeff Greenberg
January 31, 2011 at 3:18 amFredric,
I admire your humility, but I’ll not say you’re a dummy. We never know who is on the other end of the screen.
Meanwhile, yeah, this is a series of rapid cuts, with some keyframing of both scale & position.
Here’s what I’d do to ‘nail’ this. I’d download this off of youtube, and step through the frames. Each cut, I’d write down a description (like, shakes up and down+pushes in.) This series of shot descriptions will tell you exactly what to do in final cut pro.You’re not really going to find a ‘here’s how to do this’ beyond that – because each cut utilizes some slight variations. Although, yeah, it might make a good article (with the right footage.) Two keys – there were multiple takes of this and the DP kept the actor in the same general place in the frame.
Best,
Jeff G
Fredric Lean
January 31, 2011 at 4:36 amThank you Jef for the good words and for the advice.
People like me (newbie) certainly need your advices :-)) I’d wish they were tutorials or online coaching about some of the FCP effects- like this one.
If you ever stumble upon one article or even post one yourself, pliz shoot me an email.
Thank you.
Peter Wiggins
January 31, 2011 at 8:47 pmFrederic,
I’ve never used it, but you could start off with the earthquake filter that is built into FCP in the distort section.
Peter
