Activity Forums Apple Final Cut Pro Legacy Final Cut Freezes when capturing to internal drive
  • Final Cut Freezes when capturing to internal drive
    Posted by Jenna Bliss on December 16, 2010 at 6:57 pm
    Final Cut Pro freezes during batch capturing. I am using Final Cut 6.0.6 on Snow Leopard. I am capturing to 3 striped internal drives: WD Caviar Black 2TB SATA. When I capture to an external drive connected with SATA I don’t seem to crash.
    I’m not sure if I should upgrade to FCP 7 and that will solve the freezing – or if the internal drives are the sole problem. Anyone have any ideas?
    Jenna D Bliss
    John Pale replied 15 years, 9 months ago 3 Members · 2 Replies
  • Zane Barker
    December 17, 2010 at 3:02 am
    Run disk warrior on the drive.
    **Hindsight is always 1080p**
  • John Pale
    December 19, 2010 at 6:32 am
    Run AJA System Test (free download) on the drives and see what your drive performance is. One bad drive in your array can slow everything to a crawl, or freeze you up.
