Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Frame Accuracy Issues
  • Final Cut Frame Accuracy Issues
    Posted by Jason Joly on October 27, 2006 at 8:50 pm
    I have been driving myself nuts with this for a hwile and I am hoping someone mightbe able to help me. I am editing with FCP 5.04 on a G5 with Decklink HD card. I always lay off my work to Digibeta using SDI cables. 90% of the time my layoff to tape does not sync up with the sync point (2 pop) in my countdown. I am usually one frame off in either direction. (If it was consisently off in the same direction, I would adjust the offset and be set but that won’t work!) I am using the sequence preset “Blackmagic NTSC 8 Bit (29.97FPS). On the Device Control Setting I use Blackmagic NTSC 29.87 with a playback offset set to + 00;00;04 (which I was told is what I should use).
    Does anyone have any ideas or similiar experiences?
    Jason Joly replied 19 years, 11 months ago 5 Members · 6 Replies
  • Christian Kinnard
    October 27, 2006 at 11:12 pm
    I would say you have a sync issue. What kind of sync are you sending to your deck/Blackmagic board? It’s been awhile since I’ve used the blackmagic board, but i usually set my deck to video in, and have my Kona on house sync. However if my Kona gets reset to Freerun or the deck setting is changed, I will typically be a frame off either way.
    Christian
  • Aaron Neitz
    October 27, 2006 at 11:19 pm
    Black reference?
    Digi referencing Input Video or Ref?
    Assemble or Insert edit?
    Any deviations from factory settings on Digibeta?
    You shouldn’t be having a problem at all. This was stuff we stuggled with back in FCP 3 with the 1st gen SDI cards… but not today.
  • Sean Lander
    October 27, 2006 at 11:31 pm
    I can confirm this is an issue for us as well. FCP 5.1.2 QT 7.1.3. Decklink Pro.
    Trying to layoff DV via SDI to DigiBeta PAL. Will sometimes miss by 1 frame.
    Try again and it will hit the mark so there is now way of compensating for it.
  • Jeff Coleman
    October 28, 2006 at 2:54 pm
    Do you have sufficient pre-roll? I think I spoke with BMD about this once and they suspected the preroll time may be insufficient. I didn’t quite understand or perhaps believe it and never tried changing it at the time. I think a feeling of dread came over me when I learned that my captures and layoffs wouldn’t be aborted if the timecode in was different than programmed. Seemed to me a fundamental problem. But I got from them that perhaps they were at the mercy of the deck/vtr in these cases. I dunno….
    But out of curiosity, what if you made the preroll 5 seconds in FCP?
  • Sean Lander
    October 29, 2006 at 12:58 am
    Well in the last 3 years of laying off to tape it has never been a problem until now. Have been able to insert accurately 100% of the time in the past as well. So I think it’s more a recent problem with either the Decklink or FCP. I have noticed that 5.1.2 does seem to do some things a little differently.
  • Jason Joly
    October 30, 2006 at 8:40 pm
    The system was set up by someone else and there are some elements that I am not sure about. I believe the set up is as follws:
    Black Reference coming out of nv5500 Universal Sync Generator (NVision)
    DIGI referncing Input video
    I have problems with assemble and insert editing.
    To the best of my knowledge – No variation to the factory settings.
    Pre-Roll is 3 seconds, although I will try 5 seconds and see if it makes a difference.
