Well, files don’t trash themselves… so somehow you’ve managed to do it…
My suggestion is to recapture, and set your files to be saved where you know you won’t be losing them? If you’ve moved them, the app will show them as being offline, you should be able to reconnect to them. Just chose file/reconnect media with the clips that are reported offline selected in the Browser.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
