Activity Forums Video Copilot Final Cut Express Audio Speed Issue
  • Final Cut Express Audio Speed Issue
    Posted by Chad Williams on December 15, 2009 at 5:31 am
    I use FINAL CUT EXPRESS
    I have a video Clip that is 10 minutes long and a separate audio device I recorded with that turned out to be 10:03 (3 seconds longer). I have tried to speed up the audio by going to “Modify” > “Speed” > “Duration” and changing the duration to fit the duration of the video…It says is sped things up and shortened BUT when I go back to the audio it turns out that it CUT OFF PART OF THE AUDIO TO MAKE IT SHORTENED TO 10 MINUTES EVEN.
    I NEED HELP…I HAVE BEEN TRYING TO FIX THIS FOR 2 WEEKS…I HAVE READ AT LEAST 100 THREADS BUT TO NO AVAIL…I FINALLY HAVE DECIDED TO WRITE ONE MYSELF…HOPING FOR HELP.
    THANK YOU FOR ANY HELP PLEASE!
    -Chad
    Chad Williams replied 16 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
