Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Express analog capture
Posted by J.north on June 9, 2005 at 4:40 pmI am trying to capture video with FCX, digitizing using a dazzle from a hi8 camera. In FCP, it’s easy because it’s a noncontrolable device, but right now all I have in FCX, which does not have this variable to change.
How do you capture from analog with FCX?
Peter Difalco replied 21 years, 3 months ago 5 Members · 6 Replies -
Bouncing Account needs new email address
June 9, 2005 at 6:00 pm[j.north] “How do you capture from analog with FCX?”
A good method is to copy any analog source to a DV tape first, then capture the DV tape.
J.north
June 9, 2005 at 6:17 pmA Two Pass system is the only way to go. I’m trying to help this guy upgrade from iMovie, which doesn’t require anything complex. Is FCX stupid or something?
Shane Ross
June 9, 2005 at 7:22 pm[j.north] “Is FCX stupid or something?”
In a way…
It is a very simplified version of FCP. Not nearly as many options. And it is designed to work with DV material ONLY. NO analogue input, and only a controllable DV camera. It does not have the uncontrollable device option that FCP has.
Kevin Monahan
June 9, 2005 at 9:50 pmWhich means….
Start dubbin’!!
Kevin Monahan
Author – Motion Graphics and Effects in Final Cut Pro
fcpworld.com -
Peter Difalco
June 16, 2005 at 8:25 pmI am using a $300 Canopus ADVC-100 analog/DV converter bridge to accomplish exactly what you want to do. Final Cut Express sees it as a deck and will digitize from it.
One caveat: the first time you stop capturing is the last time, because the next time you try to hit capture FCE detects a time code problem. So you have to close FCE and then re-open it … rinse and repeat.
No, it’s not convenient, but hey, it’s cheaper than replacing editing SVHS decks with DV decks and replacing FCE with FCP, so give it a shot.
Bon Chance,
Peter DiFalco
Technical Supervisor
Academy of Art University
