Activity › Forums › RE:Vision Effects › Final Cut Express
  • Pierre Jasmin
    July 2, 2007 at 10:26 pm
    Not right now, it’s not really an option for the type of things we do.
    I know Premiere Elements on windows (that’s what $99?) is supposed to support our plugins… not sure they will release a Mac version once the CS3 rollout is over.
    For now, the applications listed at the link below are the only one we officially support:
    https://revisionfx.com/products/twixtor/compatibility/
    Pierre
    RE:Vision Effects
  • Dave Iron
    June 30, 2008 at 7:58 am
    mo va a cagher.com Espress on FinalCut
    Dave Iron (AL)
  • Pierre Jasmin
    June 30, 2008 at 9:16 pm
    If I understand your question properly 🙂
    For your information,
    FCE might share the same source code as FCP but lags some dot versions before what makes it in FCP comes to FCE
    So at some point Twixtor FxPlug will start to work in FCE (the changes Apple did so it works will be part of the build) – At that point we will add FCE as supported application.
    Pierre
  • Pierre Jasmin
    April 12, 2009 at 4:02 am
    OK, it’s now possible to run Twixtor in FCE (4.0.1 and over)
