Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Express 3.5 sees no audio from Mbox 2
  • Final Cut Express 3.5 sees no audio from Mbox 2
    Posted by Shayne Weyker on July 30, 2007 at 3:42 am
    I’m working with a 1Ghz dual CPU G4 that has FCE 3.5 and an Mbox 2 audio interface, connected to a powered USB hub. I don’t have the option of connecting the MBox 2 directly. The audio is coming tot he Mbox from a mixer board in the next room via spdif or XLR (can’t recall which)
    I’d like to use the FCE voice-over feature, but FCE see no signal coming out of the Mbox 2. The funny thing is that
    1) FCE lists the Mbox 2 on the list of sources you can select
    2) Pro Tools LE sees the signal just fine on the same machine.
    The simple obvious solution is to use PT LE, but I’m trying to make the workflow as easy as possible even though PT is the better tool.
    As far as I can tell this G4 has no analog audio input.
    How might I most simply and cheaply fix this problem?
    Some people have suggested looking for new drivers for the Mbox 2 but I haven’t been able to find any.
    Shayne Weyker
    https://weykervideo.com
    Kevin Weaver replied 15 years, 12 months ago 3 Members · 3 Replies
  • Tom Wolsky
    July 30, 2007 at 4:06 am
    Did you look at the audio input selections in System Preferences?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Shayne Weyker
    August 1, 2007 at 8:53 pm
    Audio input is set to Mbox 2.
    Shayne Weyker
  • Kevin Weaver
    October 5, 2010 at 4:02 pm
    did you ever figure this out?
    having the same problem
