Activity › Forums › Blackmagic Design › final cut export of Decklink Quicktimes turn greenish
  • final cut export of Decklink Quicktimes turn greenish
    Posted by Myron Lenenski on January 2, 2008 at 6:59 pm
    Has anyone else ever had this problem. We downloaded a Blackmagic filter, applied to the footage which fixes it in the project, but we want to export anything to a new movie, it’s still greenish.
    This is mostly B&W footage, so there shouldn’t be any color to speak of anyway.
    Suggestions?
    Kristian Lam replied 18 years, 8 months ago 4 Members · 4 Replies
  • Kristian Lam
    January 3, 2008 at 4:59 am
    Could you please let us know what format your timeline is in?
    What format are you exporting it to? 10-bit or 8-bit?
    What version of Final Cut Pro, OS X, Quicktime etc?
    regards
    Kristian Lam
    Blackmagic Design
  • Katelyn Howes
    January 3, 2008 at 9:19 pm
    The same thing is happening to me and my timeline is DV NTSC 48; Final cut 6; OS X 10.5 and quicktime 7.3. I’m simply trying to export a still image from a single frame of my film and It’s turning green. It used to be greenish in the project too but I changed the sequence setting to render in RGB. I also downloaded a filter that the Final Cut site told me to and that all fixed it in the project but the problem comes back whenever I try to export it. Even as a non self-contained quicktime reference file. Any help would be great.
  • Del Chapple
    January 8, 2008 at 2:27 am
    i might be out on a limb here but.. dv video is sampled with mainly green (y) then the other 2 channels are sampled 4x less red-y and blue-y. so you got alot of green in the video to start with. so if you export back to dv you have even more green 4:2:0 or 4:1:1..? try an RGB codec animation, photo jpeg or even a 4:2:2 8/10 bit codec and see if it gets better. send me a sample..
    del
    you cant hear my inner voice scream… can you..?
  • Kristian Lam
    January 8, 2008 at 4:07 am
    Hi Katelyn,
    This should not be happening. You should contact our support team together with a sample of the image you’ve exported and if possible a frame or two of the DV file so that they can have a look.
    support[at]blackmagic-design.com
    Please make sure you attach a link to this thread.
    regards
    Kristian Lam
    Blackmagic Design
