Activity Forums Apple Final Cut Pro Legacy Final Cut Effects Not Working
  • Final Cut Effects Not Working
    Posted by Pete Stringfellow on November 14, 2008 at 6:04 pm
    The message:
    “The effect “Bad TV” failed to render: Your hardware cannot render at the requested size and depth.”
    So, all of the effects are doing this and my output size is just NTSC (720×470)…nothing extravagant. I bought the best Intel Mac you can buy, I have the latest FCP..and I have 8GB RAM, surely that can’t be the problem.
    Any ideas? Pretty frustrating. :-/
    John Fishback
    replied 17 years, 10 months ago
    6 Members · 11 Replies
  • 11 Replies
  • Kevin Monahan
    November 14, 2008 at 6:18 pm
    720 x 470? Please explain that non-standard frame size first of all.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Pete Stringfellow
    November 14, 2008 at 6:21 pm
    Oooops!!!
    I meant 720×480 … my bad. :-/
  • Kevin Monahan
    November 14, 2008 at 6:45 pm
    What are your sequence settings? DV?
    Kevin Monahan
  • Pete Stringfellow
    November 14, 2008 at 6:54 pm
    It’s the “right out of the box” DV settings:
  • Arnie Schlissel
    November 14, 2008 at 7:06 pm
    I’m not sure that this has anything to do with it, but I noticed that your source footage is .dv. What is the frame size of the source?
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Kevin Monahan
    November 14, 2008 at 7:11 pm
    Just tested my Bad TV filter. Working fine.
    Kevin Monahan
  • Andrew Kimery
    November 14, 2008 at 9:09 pm
    [Arnie Schlissel] “I’m not sure that this has anything to do with it, but I noticed that your source footage is .dv. What is the frame size of the source?”
    .DV would be my first guess as the source of the problem. .DV has a different data rate than the Apple DV codec and has given me fits in the past when I’ve used it w/FCP.
    -A
  • John Fishback
    November 14, 2008 at 10:05 pm
    Are you set to render in 8-bit YUV in the Sequence Settings>Video Processing tab? I seem to recall some posts awhile back about folks having render issues and that fixed it.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • John Fishback
    November 15, 2008 at 10:39 pm
    I just found a post with rationale on this subject. https://forums.creativecow.net/readpost/221/128
    John
  • David Bogie
    November 17, 2008 at 8:46 pm
    How many graphics cards in yoru machine and how many are hooked up to monitors?
    bogiesan
