Activity › Forums › Apple Final Cut Pro Legacy › Final Cut dies
  • Posted by Tor The viking on November 29, 2006 at 7:12 pm
    Final Cut just won’t come out and play. I’ve got a Mac Power PC Duo 2.7Ghz, 5 GB ram, 10.4.8 and FC 5.1.2. Final Cut starts, but when it comes to loading video effects, it just quits. I’ve tried dumping the preference files, both system and user, and reinstalling the program. The other programs, Compression, Motion etc works just fine.
    Anyone wiser than have some answers?
    I’ll be very grateful!
    Tor
    From the great woods of Norway…
    Bill Kelly replied 19 years, 10 months ago 6 Members · 5 Replies
  • Jeremy Garchow
    November 29, 2006 at 7:47 pm
    DId you do a clean install or just an update? Any 3rd party plugins or codecs installed that aren’t compatible?
    Check these out:
    https://docs.info.apple.com/article.html?artnum=301838
    https://docs.info.apple.com/article.html?artnum=304477
    https://docs.info.apple.com/article.html?artnum=304456
    Jeremy
  • Steve Eisen
    November 29, 2006 at 8:39 pm
    trash your render files then try to open the project. If that does’nt work, move your media offline, if it opens, then you you have a corrupt media file.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Rich Rubasch
    November 30, 2006 at 12:20 am
    Or, if you have any old Avid codecs loaded in the Library-Quicktime folder take them out…that did it for me.
    Rich Rubasch
    Tilt Media
  • Rafael Amador
    November 30, 2006 at 1:59 am
    Hi Tor,
    Its happens the same to me few month ago and the reason was a free plugin that I downloaded from internet. I started FC without the therd -part plugins and fine. After I founf the one giving the problem.
    Salud,
    Rafael
  • Bill Kelly
    November 30, 2006 at 12:19 pm
    Also, you may want to try loading an older version of your project from the Autosave Vault. You may have a corrupt project file that’s causing FCP to crash when it’s opening up.
