Activity Forums Apple Final Cut Pro Legacy Final Cut creating HUGE files during capture
  • Final Cut creating HUGE files during capture
    Posted by Bergsandwich on November 17, 2007 at 9:33 pm
    i may have accidentally posted this twice, and if so i apologize. anyhow, here’s the story-
    i recently had a terabyte drive installed on my first-gen G5. the contents of the drive that were previously in that slot were cloned onto the new drive.
    when i try to capture to the new drive, final cut only makes it through about five or six minutes of footage before crashing, and the file it creates is over 800GB, which shouldn’t be. when i capture to my other drive with the same settings, this doesn’t happen.
    the store where i had my drive installed says this is a final cut issue, but since it only happens on the new drive, i don’t think it is. any thoughts?
    Mark Barroso replied 18 years, 8 months ago 6 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    November 17, 2007 at 9:44 pm
    #10 Capture now makes large file, Beachball
    Shane’s Stock Answer #10: ALLOCATING DISKSPACE
    1) Set a limit on Capture Now. Never have that box unchecked. Set it to 60 min if you want the whole tape.
    2) Do not under any circumstances run any anti-virus/filesaver software. Including Norton and Virex. Sure, Apple doles out Virex for free, but FCP doesn’t cooperate with it very well.
    If you absolutely feel you must keep Virex installed on your system then use Kevin’s script to shut it off before you use FCP:
    https://discussions.info.apple.com/webx?13@85.zPgDaaNeQzT.323013@.68a85d17
    3) Do not capture to your main system drive.
    4) Check the format of the drive you are capturing to. It should be Mas OS Extended, jornalling off. If it isn’t, copy your files from it and re-initialize it. If it is any other format, you will encounter problems. If not at first, then eventually.
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
  • Tom Brooks
    November 18, 2007 at 1:10 pm
    Many thanks for running this valuable service of “Shane’s Stock Answers” and dealing with such essential information as “Getting Organized.”
  • Mark Barroso
    November 26, 2007 at 8:25 pm
    Did this fix your problem? It seems a lot of people are having this problem of a HUGE file being created on capture. BTW Shne, love your DVD about capturing. Does it come with one free phone call?
    FCP 4.5 /
    OS 10.4.9 /
    1Ghz G4 powerbook + 1 G ram /
    LaCie External drive FW 400 150 GB /
    playback deck: Pan dv2500
  • John Urban
    December 11, 2007 at 3:28 am
    Same problem here.
    Loaded the latest Software update and I think that
    included Quicktime and a security update. Since then
    I can’t load video. I’ll have a 150 free gigs on an external
    HD and after only a few minutes of importing video it
    freezes and when I check the external HD it says there
    are only a couple of gigs left. Well, 6 minutes of DV is
    NOT 148 gigs. HELP??? PLEASE???
    John
    Mac G4
    Dual 1 Ghz Power PC
    10.3.9
  • Dom Brassey
    January 19, 2008 at 4:19 pm
    Same problem here; 5 minutes of captured video is creating a 113GB QuickTime file, then freezing up with a spinning rainbow cursor because my HD is out of space.
    FinalCut Pro (4.5) will not force quit; Quicktime Player (7.4 (92), updated 1/16/2008) to take a peek at the enormous file, QuickTime Player is also non-responsive, and won’t force quit. Same story when I try to play the file in LiveType.
    I tried capturing again with the QuickTime application file (32MB) in the trash; same problem.
    I haven’t touched my capture settings; I have 109GB available on the external HD that I’m capturing to.
    Any ideas? (Thanks in advance.) –domlet.
  • John Urban
    January 20, 2008 at 12:58 am
    Dom,
    The problem was and still is Quicktime 7.3.
    Doesn’t work with FCP 4.5.
    I was just about to buy my new Apple and I
    did so no more problems for me, but unfortunately
    for you, you either have to reinstall your OS and
    go back to QT 7.1 or upgrade FCP to 5.
    Best of luck,
    John
  • Mark Barroso
    January 20, 2008 at 1:54 pm
    My problem was created by upgrading to QT 7.3 and using it with FCP 4.5. When using Captured Now, it created huge .av files. My problem was solved by reverting back to QT 7.2, which was a major pain (ended up having to re-install OS). I got my answer in another post.
    I am using an old G4 Powerbook and don’t think it can handle later versions of FCP. The preferred solution would be to upgrade everything to the latest versions, but for me it was cost prohibitive, so I went BACK to the tried and true method.
    Hope this helps,
    Mark
    FCP 4.5 /
    OS 10.4.9 /
