Activity › Forums › Apple Final Cut Pro Legacy › Final Cut crashing while using still photos
Posted by Warren Watson on February 5, 2006 at 6:58 pmI’m having trouble w/ FCP (v4.1) crashing when I try to use a still photo (in JPEG format). I can import from a CD, thumb drive or another disk with no problem, but within 5 seconds after I click on a still image, FCP crashes. Anyone have any idea why this happens and how to fix it? I had this problem a few years ago, but it only happened once in a while. This time it’s happening w/ every photo.
WarrenMichael Peele replied 20 years, 6 months ago 8 Members · 10 Replies -
Sean Mcphillips
February 5, 2006 at 10:54 pmSounds like they’re either too big (try reducing resolution – video only requires 72dpi) or they’re CMYK (FCP needs RGB – change it in Photoshop under Image> Mode > RGB Colour
Sean
Shane Ross
February 5, 2006 at 10:54 pmTry trashing the preferences. Download FCP rescue…the FCP 4 version.
https://www.pistolerapost2.com/fcprescue
How big are these pictures? Dimensions?
Shane Ross
Alokut Productions
http://www.lfhd.net -
Michael Alberts
February 6, 2006 at 3:40 amIf your workin in FCP 4 than you need to consider to dimensions of the still. If it’s over 4000×40000 pixels your going to have issues in FCP. Graphics that size will slow FCP down to a crawl, and if you don’t have enough RAM could cause other issues. For you sanity the still doesn’t need to be more that twice your screen rez.
Michael Alberts
Ambidextrous Productions, Inc. -
Ron Dylewski
February 6, 2006 at 1:50 pmHi –
I’ve had this issue from time to time as well, though it doesn’t always seem consistent in terms of how large an image it takes to lock up/crash FCP. With that said, I have found that the vertical dimension seems to be the one that causes the most heartache. I know that sounds odd, but, if you’re like me, you don’t always get handed images which are in either 4:3 or 16:9 — they are sometimes huge vertically.
Ron
Photos, news, memories and musings on the great American Roadside experience
https://www.theamericanroadside.com
Are you a collector? Put your collection online for free at What A Collection.com!
https://www.whatacollection.com -
Warren Watson
February 6, 2006 at 4:29 pmThanks for your help and I went back to check the info you gave me. Here is what I have:
– They are all JPEGs at 72dpi.
– none are more than 800 x 600
– All are in RGB, none in CMYK
– I have a few I’m trying to use for lower 3rds where the original size is 600 x 150 (which will be reduced for the lower 3rd).About 5-10 seconds I click on the image and it pops into the viewer, it’ll crash. I don’t even get a chance to change the size, add a blur or even put it straight into the timeline before it crashes. I wonder if changing the files to a PSD or TIF would help.
Warren -
Warren Watson
February 6, 2006 at 4:39 pmWell, I just changed a couple of the files to a TIF and a PNG file, same thing, constant crash. I’m perplexed. Is the bar open yet? 😉
Warren
Tom Wolsky
February 6, 2006 at 5:11 pmHow much RAM do you have? Have you increased the still image cache size? May be bad RAM.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
Ron Dylewski
February 6, 2006 at 5:27 pmJust for kicks, try changing the size by a few pixels and re-saving. I’ve had that work (for no apparent reason) from time to time.
Ron
Ddcawoods
February 6, 2006 at 6:42 pmI had similar issuess consistently whenever I used version 4.x w/jpeg files. Usually, a “green screen” would appear where I previously had a jpeg image. Very often, FCP would crash when i had jpegs in my sequence. When I convert them to PICT, the problem always goes away. With FCP 5.x I have been able to use jpegs without a hiccup.
David
Michael Peele
February 7, 2006 at 12:27 amYou are not importing the file in FCP directly from a CD are you?
If so FCP is just linking to the file on the CD and I can totally see this causing issues (especially if you remove the CD!)
Good luck,
Mike
