Activity Forums Blackmagic Design final cut crashing. please help.
  • final cut crashing. please help.
    Posted by Cory Tardy on October 4, 2009 at 2:27 pm
    I have a 8 core 10.6.1 running snow leopard with a decklink extreme hd 3 card. quite often when i try to open the log and transfer utility fcp crashes. is this a known problem? are there any fixes? all of my firmware for the card is current as well. thanks!
    Kristian Lam replied 16 years, 11 months ago 3 Members · 2 Replies
  • Kaku Ito
    October 4, 2009 at 5:27 pm
    Similar issue I have occasionally is that FCP crashes upon booting up.
    I found this happens if the volume I had assigned had some problems then it crashes.
    So, you might wanna see the scratch volume that you set for the capturing is healthy or not.
    Kaku Ito
    http://www.musetexsystem.com
    http://www.rockrc.net
    http://www.brightminds.jp
  • Kristian Lam
    October 5, 2009 at 11:39 am
    Hi Cory,
    Can you specify exactly what version of drivers you’re running? Sometimes, you may think it’s current but it’s actually not the case.
    regards
    Kristian Lam
    Blackmagic Design
