Final Cut Crashing Help Please!
Hi everyone,
Well Im at the back end of an edit which has started to crash a lot.
A lil bit of info, The project is using P2 format and a recent Panasonic HD handy cam (I know there are issues with this Handy Cam codec, but the project has been fine up until last week).
I am running approx 5 TBs of media on 2 Firewire 800 drives. One is a Raid 5 with 3.6 TBs of usable storage in 800 Array and the other is a 1 TB.
I have been cutting on a lap top (see specs in error msg below) and a 8 core mac. The crashing originally only occurred on the 8 core, but now its happening on the laptop also.
I have cleared out space on all the drives so they aren’t pushed to the limits.
The project file is 400 meg!
I have tried deleting some user prefs and it seemed to help a lil but the problem hasnt been solved.
Also we have made copies of sequences and footage through Media Manager (for the assistant editor to work on at the same time) and then relinked the edits again later and ditched the copied files.
These files dont link to the master files within the project (even thought they are the same) eg. I can match frame them from the timeline, but then when I wont it to open it says the master clip is not in the project – do you want to make a new one? Is there anyway to refresh the media directories and files in the project and timeline? (I dont mean reconnect media, because that is pretty unhelpful so far).
Dont know if this is an issue, because it was running fine until recently.
I am starting to freak out with the deadline this thurs! Any help would be MUCHO Appreciated!
Cheers from Kent
This is the lastest error message:
Model Name: MacBook Pro 15″
Model Identifier: MacBookPro2,2
Processor Name: Intel Core 2 Duo
Processor Speed: 2.16 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 4 MB
Memory: 4 GB
Bus Speed: 667 MHz
Boot ROM Version: MBP22.00A5.B07
SMC Version: 1.12f5Process: Final Cut Pro [2518]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 6.0.5 (6.0.5)
Build Info: FCPApp-810171515~36
Code Type: X86 (Native)
Parent Process: launchd [80]Date/Time: 2009-04-14 07:40:44.486 +1200
OS Version: Mac OS X 10.5.6 (9G55)
Report Version: 6Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000008
Crashed Thread: 0Thread 0 Crashed:
0 com.apple.FinalCutPro 0x0042517a VideoPipe::GetSourceImageRect(Output*, float*) + 100
1 com.apple.FinalCutPro 0x00449674 SetupSrcCanvasN(XXGlobals*, EffectTree*, long, long, Output*, bool*) + 2274
2 com.apple.FinalCutPro 0x0044a5e1 DecodeEffectFrameN(XXGlobals*, EffectTree*, long, unsigned char, Output*, bool*) + 273
3 com.apple.FinalCutPro 0x0044b417 DecodePipeTree(XXGlobals*, Output*) + 633
4 com.apple.FinalCutPro 0x00417939 FCPMediaHandler::RenderFrames(long long, bool) + 4049
5 com.apple.FinalCutPro 0x00417f54 FCPMediaHandler::Idle(long, long, long*, TimeRecord*) + 582
6 com.apple.FinalCutPro 0x00418f49 FCPMHIdle(FCPMediaHandler*, long, long, long*, TimeRecord*) + 45
7 …ple.CoreServices.CarbonCore 0x9369c09f CallComponentFunctionCommon + 1403
8 com.apple.FinalCutPro 0x004119c3 FCPMHDispatch(ComponentParameters*, char**) + 55
9 …ple.CoreServices.CarbonCore 0x9369ba05 CallComponentDispatch + 29
10 …ickTimeComponents.component 0x92169d76 MediaIdle + 61
11 …ickTimeComponents.component 0x91a4ed06 doGenericIdle + 2091
12 …ickTimeComponents.component 0x91a50466 GenericMoviesTask + 337
13 …ple.CoreServices.CarbonCore 0x9369c09f CallComponentFunctionCommon + 1403
14 …ickTimeComponents.component 0x91a4fe53 GenericComponentDispatch + 170
15 com.apple.FinalCutPro 0x004119df FCPMHDispatch(ComponentParameters*, char**) + 83
16 …ple.CoreServices.CarbonCore 0x9369ba05 CallComponentDispatch + 29
17 com.apple.QuickTime 0x93c10003 MediaMoviesTask + 61
18 com.apple.QuickTime 0x93b6bf54 TaskMovie_priv + 4811
19 com.apple.QuickTime 0x93c4ca1f MoviesTask_priv + 100
20 com.apple.FinalCutPro 0x001b06b8 DoMoviesTask(KGPlayerRec*) + 2446
21 com.apple.FinalCutPro 0x001c282d DisplayMovie(KGPlayerRec*) + 2235
22 com.apple.FinalCutPro 0x001c7444 pKGPlayerGoto(KGPlayerRec*, double, long, unsigned char) + 512
23 com.apple.FinalCutPro 0x001b0edb PlayerNotify(long, long, KGDictInt*, void*) + 143
24 com.apple.FinalCutPro 0x0010f4fa DispatchNotificationsHelp(void**, KGDictInt*, long, long, unsigned char) + 164
25 com.apple.FinalCutPro 0x0010f7e4 DispatchNotifications + 260
26 com.apple.FinalCutPro 0x0001e931 HashInsertFull(HashDict*, char*, long, unsigned char, void*, KGTypeValueContainer*, void**, unsigned char, KGDictNotifyHolder**, KGDictUndoMethod, long, unsigned char, unsigned long) + 1055
27 com.apple.FinalCutPro 0x0002006b DispatchHashDict(KGDictSelector, KGDictInt*, KGDictParams*) + 227
28 com.apple.FinalCutPro 0x00110500 pKGDictPut1(KGDictInt*, void*, long, char*) + 90
29 com.apple.FinalCutPro 0x000a6953 DisplayMatchFrameCore(KGDictInt*, KGItemSpec*, double, unsigned long) + 4969
30 com.apple.FinalCutPro 0x000a6cf3 pKGEditDisplayMatchFrame(KGDictInt*, double) + 29
31 …Pro.Plugins.Timeline Editor 0x12cb69f4 TLShowReelDupes(KGDictInt*) + 29168
32 …Pro.Plugins.Timeline Editor 0x12cc9b8c DisposeMenuStrings() + 47384
33 com.apple.FinalCutPro 0x0029c556 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 1800
34 com.apple.FinalCutPro 0x0024b803 ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 109
35 com.apple.FinalCutPro 0x0024cce1 TimelineMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 101
36 com.apple.FinalCutPro 0x002923fd pKGPanelWindowProc(long, long, KGDictInt*, void*) + 53
37 com.apple.FinalCutPro 0x002a71ef pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 93
38 com.apple.FinalCutPro 0x0014a072 HandleMenuCommand(long, unsigned char, unsigned char, unsigned char, KGErrorCode (*)(long, long, KGDictInt*, void*), void*) + 444
39 com.apple.FinalCutPro 0x0014a1dd HandleCommand(long, unsigned char, unsigned char, unsigned char) + 251
40 com.apple.FinalCutPro 0x0014fbe5 HandleKeyDown(OpaqueEventRef*, KGDictInt*, KGWindowRec*) + 1423
41 com.apple.FinalCutPro 0x001519fd DoEvent(OpaqueEventRef*, KGDictInt*) + 2971
42 com.apple.FinalCutPro 0x004000fd Events(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 69
43 com.apple.HIToolbox 0x9685d143 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
44 com.apple.HIToolbox 0x9685c57d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
45 com.apple.HIToolbox 0x9685c3e2 SendEventToEventTargetWithOptions + 58
46 com.apple.HIToolbox 0x9688b32e ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1854
47 com.apple.HIToolbox 0x9685d4fc DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2134
48 com.apple.HIToolbox 0x9685c57d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
49 com.apple.HIToolbox 0x96878ed2 SendEventToEventTarget + 52
50 com.apple.HIToolbox 0x968e5b80 ToolboxEventDispatcher + 86
51 com.apple.HIToolbox 0x968e23da RunApplicationEventLoop + 222
52 com.apple.FinalCutPro 0x0014cece KGMainEvent(void*) + 46
53 com.apple.FinalCutPro 0x002aae53 main + 59
54 com.apple.FinalCutPro 0x00003122 _start + 216
55 com.apple.FinalCutPro 0x00003049 start + 41Thread 1:
0 libSystem.B.dylib 0x939946f2 select$DARWIN_EXTSN + 10
1 libSystem.B.dylib 0x93976095 _pthread_start + 321
2 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 2:
0 libSystem.B.dylib 0x9394c3ae __semwait_signal + 10
1 libSystem.B.dylib 0x93976d0d pthread_cond_wait$UNIX2003 + 73
2 libGLProgrammability.dylib 0x9495ab32 glvmDoWork + 162
3 libSystem.B.dylib 0x93976095 _pthread_start + 321
4 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 3:
0 libSystem.B.dylib 0x9394520e semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x93977206 _pthread_cond_wait + 1267
2 libSystem.B.dylib 0x939bc539 pthread_cond_wait + 48
3 com.apple.FinalCutPro 0x004292ad Synchronizable::Wait() + 47
4 com.apple.FinalCutPro 0x004152e8 DisplayQueue::Run() + 702
5 com.apple.FinalCutPro 0x00453544 Thread::RunHelper(void*) + 20
6 libSystem.B.dylib 0x93976095 _pthread_start + 321
7 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 4:
4 com.apple.FinalCutPro 0x004cc3e3 WorkUnitPerformer::Run() + 55
7 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 5:
0 libSystem.B.dylib 0x939451c6 mach_msg_trap + 10
1 libSystem.B.dylib 0x9394c9bc mach_msg + 72
2 com.apple.CoreFoundation 0x932e20ae CFRunLoopRunSpecific + 1790
3 com.apple.CoreFoundation 0x932e2d34 CFRunLoopRun + 84
4 com.apple.DVCPROHDMuxer 0x192930fb AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 297
5 libSystem.B.dylib 0x93976095 _pthread_start + 321
6 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 6:
3 com.apple.CoreFoundation 0x932e2cd8 CFRunLoopRunInMode + 88
4 com.apple.audio.CoreAudio 0x962515dc HALRunLoop::OwnThread(void*) + 160
5 com.apple.audio.CoreAudio 0x96251464 CAPThread::Entry(CAPThread*) + 96
7 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 7:
4 ….CoreMediaIOServicesPrivate 0x90fecf88 MIO::DAL::RunLoop::OwnThread(void*) + 160
5 ….CoreMediaIOServicesPrivate 0x90fef108 CAPThread::Entry(CAPThread*) + 96
7 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 8:
0 libSystem.B.dylib 0x93945226 semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x939771ef _pthread_cond_wait + 1244
2 libSystem.B.dylib 0x93978a73 pthread_cond_timedwait_relative_np + 47
3 …ple.CoreServices.CarbonCore 0x93692dd2 TSWaitOnConditionTimedRelative + 246
4 …ple.CoreServices.CarbonCore 0x93692bb2 TSWaitOnSemaphoreCommon + 422
5 …ickTimeComponents.component 0x919e0bee ReadSchedulerThreadEntryPoint + 4724
7 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 9:
3 ….Helium.HSmoothMotionRender 0x2dda44f8 Synchronizable::Wait() + 46
4 ….Helium.HSmoothMotionRender 0x2dd04933 HSmoothMotionRender::GetComputeSmoothMotionRequest() + 55
5 ….Helium.HSmoothMotionRender 0x2dd04dbf ComputeSmoothMotionTask(void*) + 19
7 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 10:
4 com.apple.DesktopServices 0x96e4cef3 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 123
5 …ple.CoreServices.CarbonCore 0x936b20a3 PrivateMPEntryPoint + 56
7 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 11:
4 com.apple.DesktopServices 0x96e4d06c TFSEventsNotificationTask::FSEventsNotificationTaskProc(void*) + 216
7 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 12:
2 …ple.CoreServices.CarbonCore 0x936b3ecf TSWaitOnCondition + 126
3 …ple.CoreServices.CarbonCore 0x93692da6 TSWaitOnConditionTimedRelative + 202
4 …ple.CoreServices.CarbonCore 0x936b3b4c MPWaitOnQueue + 208
5 com.apple.DesktopServices 0x96e5802a TNodeSyncTask::SyncTaskProc(void*) + 84
6 …ple.CoreServices.CarbonCore 0x936b20a3 PrivateMPEntryPoint + 56
7 libSystem.B.dylib 0x93976095 _pthread_start + 321
8 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 13:
0 libSystem.B.dylib 0x93975906 kevent + 10
2 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 14:
3 com.apple.Foundation 0x910e275c -[NSCondition waitUntilDate:] + 236
4 com.apple.Foundation 0x910e2570 -[NSConditionLock lockWhenCondition:beforeDate:] + 144
5 com.apple.Foundation 0x910e24d5 -[NSConditionLock lockWhenCondition:] + 69
6 com.apple.AppKit 0x92566d90 -[NSUIHeartBeat _heartBeatThread:] + 753
7 com.apple.Foundation 0x9109c7ed -[NSThread main] + 45
8 com.apple.Foundation 0x9109c394 __NSThread__main__ + 308
9 libSystem.B.dylib 0x93976095 _pthread_start + 321
10 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 15:
5 …ple.CoreServices.CarbonCore 0x936bb220 AIOFileThread(void*) + 1056
7 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 16:
1 libSystem.B.dylib 0x9394cce5 pthread_mutex_lock + 569
2 com.apple.Helium.HeliumRender 0x15a902b4 hg_pthread_loop(void*) + 52
4 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 17:
5 …ple.CoreServices.CarbonCore 0x936c39c8 TimerThread + 74
7 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 18:
0 libSystem.B.dylib 0x9394521a semaphore_timedwait_trap + 10
1 …ple.CoreServices.CarbonCore 0x936c549b MPWaitOnSemaphore + 125
2 com.apple.DVCPROHDCodec 0x13c9498d 0x13c93000 + 6541
3 …ple.CoreServices.CarbonCore 0x936b20a3 PrivateMPEntryPoint + 56
4 libSystem.B.dylib 0x93976095 _pthread_start + 321
5 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 19:
5 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 20:
5 libSystem.B.dylib 0x93975f52 thread_start + 34Thread 0 crashed with X86 Thread State (32-bit):
eax: 0xbfffc974 ebx: 0x00000000 ecx: 0x00000000 edx: 0x0075e460
edi: 0x0e038098 esi: 0xbfffca30 ebp: 0xbfffc998 esp: 0xbfffc920
ss: 0x0000001f efl: 0x00010282 eip: 0x0042517a cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000008Binary Images:
0x1000 – 0x75cfe8 com.apple.FinalCutPro 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0xb23000 – 0xb26fe0 +KGCore ??? (???) /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
0xb2d000 – 0xb2dffc com.apple.iokit.dvcomponentglue 1.9.5 (1.9.5) <0759a2500bb678c4e6fc1c4a90d17e03> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0xb32000 – 0xb41ff7 com.apple.AERegistration 1.2 (72) /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
0xb53000 – 0xb5aff3 com.apple.AEProfiling 1.2 (18) /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
0xb62000 – 0xccdfeb com.apple.prokit 4.5 (722) <372314d5b0a6b68af0ba352d0a910e1a> /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0xdae000 – 0xddeffb com.apple.AVCVideoServices 1.0 (38) /Applications/Final Cut Pro.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
0xe00000 – 0xe74ffb com.apple.ProFX 1.2.3 (1.2.3) /Library/Frameworks/ProFX.framework/Versions/A/ProFX
0xe9f000 – 0xf97fe0 com.apple.DiskImagesFramework 10.5.4 (195.2.2) <62a6764ff62868031f882857791ff1d6> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0xffd000 – 0x1053fff com.apple.proapps.MIO 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
0x108f000 – 0x1099fee com.apple.finalcutstudio.prometadatasupport 0.5 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
0x10a3000 – 0x10d9fff com.apple.MediaKit 9.1 (401) <36149a69962ed3101199093a6220ef74> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x10ea000 – 0x11b3ff5 com.apple.DiscRecording 4.0.3 (4030.4.3)/System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x121e000 – 0x1249ffb libcurl.4.dylib ??? (???) <54ada27deb3b4ff7043d8836264eca0d> /usr/lib/libcurl.4.dylib
0x1253000 – 0x1285fff com.apple.FWAVCPrivate 1.0 (43) /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
0x1500000 – 0x153ffff com.apple.vmutils 4.1 (104) <2fcd53ce313bb6050bfaf0ac6c1b5ead> /System/Library/PrivateFrameworks/vmutils.framework/vmutils
0x17dd000 – 0x17e5ff7 com.apple.proapps.mrcheckpro 1.4 (204) /Applications/Final Cut Pro.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
0xbb35000 – 0xbb51ff7 GLRendererFloat ??? (???)/System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0xbb78000 – 0xbb79fff com.apple.DVCPROHDVideoOutputCodec 1.3 (1.3) /Library/QuickTime/DVCPROHDVideoOutputCodec.component/Contents/MacOS/DVCPROHDVideoOutputCodec
0xe1b7000 – 0xe1c1ffe com.apple.URLMount 3.1.1 (3.1.1) <529901878c2849bede5ee2536293c9d3> /System/Library/PrivateFrameworks/URLMount.framework/URLMount
0xe6f8000 – 0xe8cafe7 com.apple.RawCamera.bundle 2.0.10 (2.0.10)/System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0xe94f000 – 0xead2fe3 GLEngine ??? (???)/System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0xeb00000 – 0xedaafe9 com.apple.ATIRadeonX1000GLDriver 1.5.36 (5.3.6) <3f9984c88184d39af0ed1e486ab4616a> /System/Library/Extensions/ATIRadeonX1000GLDriver.bundle/Contents/MacOS/ATIRadeonX1000GLDriver
0xfe1a000 – 0xfe45fe7 com.apple.FinalCutPro.Plugins.AfterEffects 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
0xfe4f000 – 0xfe53ff3 com.apple.FinalCutPro.Plugins.AudioGroupsExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
0xfe58000 – 0xfe6fff7 com.apple.FinalCutPro.Plugins.AudioMixer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
0xfe7e000 – 0xfe9bff7 com.apple.audio.midi.CoreMIDI 1.6.1 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0xfeb3000 – 0xfec7fcf com.apple.proapps.ControlSurfaceSupport 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
0xfedd000 – 0xfefbfe3 libexpat.1.dylib ??? (???)/usr/lib/libexpat.1.dylib
0xff03000 – 0xffbcfea com.apple.FinalCutPro.Plugins.Browser 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
0xffd7000 – 0xffdcfff com.apple.FinalCutPro.Plugins.Cache Manager 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
0xffe1000 – 0xffecff5 com.apple.FinalCutPro.Plugins.CTHelper 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
0xfff4000 – 0xfff7ffc com.apple.FinalCutPro.Plugins.FinalTouchExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FinalTouchExport.bundle/Contents/MacOS/FinalTouchExport
0x10000000 – 0x1005efef com.apple.proapps.AudioMixEngine 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
0x12751000 – 0x12767fff com.apple.FinalCutPro.CinemaTools 4.0.1 (4.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
0x12773000 – 0x12797ffb com.apple.FinalCutPro.Plugins.EditTape 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
0x127a7000 – 0x127affff com.apple.FinalCutPro.Plugins.Effect Builder 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
0x127b4000 – 0x127bfff2 com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
0x127c8000 – 0x127d9fff com.apple.FinalCutPro.Plugins.FilterCustomEd 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
0x127df000 – 0x127f4ff3 com.apple.FinalCutPro.Plugins.FilterViewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
0x127fa000 – 0x127fbfff com.apple.FinalCutPro.Plugins.Text Window 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
0x12900000 – 0x12945feb com.apple.FinalCutPro.Plugins.EDL Export 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
0x1295b000 – 0x1298fff6 com.apple.FinalCutPro.Plugins.FCS Engine 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
0x1299a000 – 0x129b8fc3 com.apple.FinalCutPro.Plugins.Flash 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
0x129c9000 – 0x129d6ff3 com.apple.FinalCutPro.Plugins.GenViewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
0x129dc000 – 0x129e0fff com.apple.FinalCutPro.Plugins.LayerFileReader 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
0x129e5000 – 0x12a30ffb com.apple.FinalCutPro.Plugins.Media Manager 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
0x12a3d000 – 0x12a5006e com.apple.FinalCutPro.Plugins.MolokiniSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
0x12a5e000 – 0x12a72fff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
0x12a7f000 – 0x12a93ff3 com.apple.FinalCutPro.Plugins.Motion Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
0x12a99000 – 0x12ab5ff7 com.apple.FinalCutPro.Plugins.Movie Analyzer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
0x12ac5000 – 0x12adbfeb com.apple.FinalCutPro.Plugins.Movie Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
0x12ae7000 – 0x12aebfff com.apple.FinalCutPro.Plugins.NuggetExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
0x12af0000 – 0x12ba8fc7 com.apple.FinalCutPro.Plugins.OMF Audio Export 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
0x12bc7000 – 0x12bd0ff7 com.apple.FinalCutPro.Plugins.Perf Analyzer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
0x12bd5000 – 0x12bebff9 com.apple.FinalCutPro.Plugins.ProAppsIntegration 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
0x12bfb000 – 0x12c08ff3 com.apple.FinalCutPro.Plugins.Pulldown Support 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
0x12c11000 – 0x12c50ff7 com.apple.FinalCutPro.Plugins.QTM Reader 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
0x12c5d000 – 0x12c65fef com.apple.FinalCutPro.Plugins.QuickView 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
0x12c6a000 – 0x12c7aff0 com.apple.FinalCutPro.Plugins.Relink Media 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
0x12c81000 – 0x12cfcff4 com.apple.FinalCutPro.Plugins.Timeline Editor 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
0x12d07000 – 0x12d0efef com.apple.FinalCutPro.Plugins.Transcoder 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
0x12d14000 – 0x12d26ffb com.apple.FinalCutPro.Plugins.Transition Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
0x12d2c000 – 0x12d41ff3 com.apple.FinalCutPro.Plugins.Trimming 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
0x12d47000 – 0x12d4dff7 com.apple.FinalCutPro.Plugins.VDUSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
0x12d53000 – 0x12d54fff com.apple.FinalCutPro.Plugins.Vector Accelerator 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
0x12d59000 – 0x12d6affb com.apple.FinalCutPro.Plugins.VideoLog 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
0x12d6f000 – 0x12d87feb com.apple.FinalCutPro.Plugins.VoiceOver 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
0x12d8e000 – 0x12df2ffb com.apple.FinalCutPro.Plugins.XML Support 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
0x131f6000 – 0x131f6ffd libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
0x134ff000 – 0x13511fd9 com.apple.FCP Uncompressed 422.component 1.5 (1.5) /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0x13578000 – 0x1357bfef com.apple.LiveType.component 2.1.3 (2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x13580000 – 0x135e5fde com.apple.LiveType.framework 2.1.3 (2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x13605000 – 0x1361afcf com.apple.fcp.DVOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
0x137cd000 – 0x13807fff com.apple.AppleProRes422 1.0.2 (46) /Library/QuickTime/AppleProRes422.component/Contents/MacOS/AppleProRes422
0x13853000 – 0x13c28fe5 QuickTimeH264.scalar ??? (???)/System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
0x13c93000 – 0x13cd7fe7 com.apple.DVCPROHDCodec 1.4 (231) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
0x13cec000 – 0x13d32fef com.apple.viceroy.codec 32.1 (32.1) /System/Library/Components/VCH263Codec.component/VCH263Codec
0x13d3b000 – 0x13ddefd3 com.apple.AppleHDVCodec 1.4.1 (222) <68abd695e9904f5f9074d2c4ae440637> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
0x13dfc000 – 0x13e48fe3 com.apple.AppleVAFramework 4.1.14 (4.1.14) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x13e51000 – 0x13e6bfc3 com.apple.AppleIntermediateCodec 1.2 (145) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x13e70000 – 0x13e90ff3 com.apple.IMXCodec 1.3.1 (147) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0x13ea8000 – 0x13ec1ff3 com.apple.applepixletvideo 1.2.18 (1.2d18)/System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x13ec6000 – 0x13f01fff com.apple.QuickTimeFireWireDV.component 7.6 (1290) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x13fdc000 – 0x13fe1fff com.apple.finalcutpro.dvcprohdfrcplugin 1.2.0 (16) /Applications/Final Cut Pro.app/Contents/PlugIns/DVCPROHD Frame Rate Converter.bundle/Contents/MacOS/DVCPROHD Frame Rate Converter
0x140b0000 – 0x140fdfe3 com.apple.soundtrackpro.integration 2.0.0 ()/Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
0x142fb000 – 0x142fcffc com.apple.compressor.stomp 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Compressor
0x14500000 – 0x14c35fdf +com.borisfx.TextScrambler ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
0x15841000 – 0x15851fff com.apple.QuartzComposer.FxPlugWrapper 1.2.3 (1.2.3) /Library/Application Support/ProApps/Internal Plug-Ins/ProFX/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
0x1585c000 – 0x15868fff com.apple.PluginManager 1.7.3 (34) /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
0x15874000 – 0x15884fff com.apple.fxplugframework 1.2.3 (1.2.3) /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
0x15898000 – 0x159cafe0 com.apple.motion.filters 3.0.2 (3.0.2) /Library/Application Support/ProApps/Internal Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
0x15a5f000 – 0x15a64fe3 com.apple.SmoothCamFxPlug 1.0.1 (1.0.1) /Library/Application Support/ProApps/Internal Plug-Ins/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
0x15a6b000 – 0x15a6cfff com.apple.Helium 2.1.2 (2.1.2) /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
0x15a70000 – 0x15aa4fcf com.apple.Helium.HeliumRender 1.0.2 (1.0.2) /System/Library/PrivateFrameworks/Helium.framework/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
0x15ac2000 – 0x15ac5fff com.apple.audio.AudioIPCPlugIn 1.0.5 (1.0.5)/System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x15acb000 – 0x15ad0fff com.apple.audio.AppleHDAHALPlugIn 1.6.2 (1.6.2a37) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x15ad5000 – 0x15b2bfd6 com.apple.DVCPROHDAudio 1.3 (1.3) /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
0x15b5b000 – 0x15b66ffe com.apple.fcp.TundraOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
0x15b72000 – 0x15b7eff7 com.apple.DVCPROHDVideoOutput 1.3 (1.3) /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
0x15b86000 – 0x15b8bff7 com.apple.DesktopVideoOut 1.2.4 (1.2.4) /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
0x15b90000 – 0x15b99fff com.apple.IOFWDVComponents 1.9.5 (1.9.5) <889959011cb23c11785c378264400284> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
0x15d00000 – 0x16432fc7 +com.borisfx.Title3D ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title 3D.bundle/Contents/MacOS/Title 3D
0x16e70000 – 0x175a0fef +com.borisfx.TitleCrawl ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title Crawl.bundle/Contents/MacOS/Title Crawl
0x18100000 – 0x18836ff7 +com.borisfx.VectorShape ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Vector Shape.bundle/Contents/MacOS/Vector Shape
0x19281000 – 0x192cbfec com.apple.DVCPROHDMuxer 1.3 (1.3) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0x192e9000 – 0x19312fe5 com.apple.mio.DAL.VDC 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Resources/VDC.plugin/Contents/MacOS/VDC
0x19333000 – 0x1935dfff com.apple.audio.SoundManager.Components 3.9.3 (3.9.3) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x19380000 – 0x1938bfff com.apple.compressor.MediaServerAPI 3.0.5 (3.0.5) /Library/Frameworks/MediaServerAPI.framework/MediaServerAPI
0x1939f000 – 0x193a6fff com.apple.compressor.FilterUI 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
0x193ae000 – 0x193afffc com.apple.qmaster.swamp 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
0x193d3000 – 0x193ddffc com.apple.qmaster.SwampUtil 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
0x193f8000 – 0x19404fff com.apple.compressor.StompUtil 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
0x19413000 – 0x1941cfff com.apple.qmaster.SwampService 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
0x19474000 – 0x1947ffff com.apple.qmaster.RequestProcessing 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
0x194c9000 – 0x194d7fff com.apple.qmaster.Status 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
0x197df000 – 0x197ebffe com.apple.qmaster.ClusterManager 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
0x1a000000 – 0x1a0e6d9b com.apple.AECore 3.0.5 (3.0.5) /Library/Frameworks/AECore.framework/Versions/A/AECore
0x1a17b000 – 0x1a1b9fff com.apple.compressor.ImageProcessing 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
0x1a1f0000 – 0x1a2d5fe3 com.apple.compressor.StompTypes 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
0x1a371000 – 0x1a4daffb com.apple.compressor.transcoding 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
0x1a5eb000 – 0x1a639fdf com.apple.compressor.StompUI 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
0x1a667000 – 0x1a686fed com.apple.audio.CoreAudioKit 1.5 (1.5) <82f2e52c502db7f3b32349a54209a0fe> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x1a698000 – 0x1a6d8fef com.apple.qmaster.SwampCore 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
0x1a71b000 – 0x1a758fff com.apple.qmaster.SwampTypes 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
0x1a79d000 – 0x1a7e2fff com.apple.qmaster.do 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
0x1a834000 – 0x1a845ff7 com.apple.qmaster.ServiceControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
0x1a85f000 – 0x1a8a5fff com.apple.qmaster.ContentControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
0x1a8e0000 – 0x1a8fefff com.apple.qmaster.SwampUI 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
0x1a91a000 – 0x1a926fff com.apple.qmaster.SwampExecutor 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
0x29b04000 – 0x29bc5fff com.apple.qmaster.JobControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
0x2dd00000 – 0x2ddb3fff com.apple.Helium.HSmoothMotionRender 1.0.2 (1.0.2) /System/Library/PrivateFrameworks/Helium.framework/Plug-ins/HSmoothMotionRender.bundle/Contents/MacOS/HSmoothMotionRender
0x2dde4000 – 0x2de9afff com.apple.Helium.HDominantMotionTracker 1.0.2 (1.0.2) /System/Library/PrivateFrameworks/Helium.framework/Plug-ins/HDominantMotionTracker.bundle/Contents/MacOS/HDominantMotionTracker
0x3d109000 – 0x3d16cfef com.apple.QuickTimeMPEG.component 7.6 (1290) /System/Library/QuickTime/QuickTimeMPEG.component/Contents/MacOS/QuickTimeMPEG
0x41200000 – 0x41361fe1 com.apple.QuickTimeStreaming.component 7.6 (1290)/System/Library/QuickTime/QuickTimeStreaming.component/Contents/MacOS/QuickTimeStreaming
0x70000000 – 0x700e6ff2 com.apple.audio.units.Components 1.5.2 (1.5.2) /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe00000 – 0x8fe2db43 dyld 97.1 (???) <100d362e03410f181a34e04e94189ae5> /usr/lib/dyld
0x90055000 – 0x90223ff3 com.apple.security 5.0.4 (34102) <55dda7486df4e8e1d61505be16f83a1c> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x90224000 – 0x90296fff com.apple.PDFKit 2.1.2 (2.1.2) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x90354000 – 0x9048cff7 libicucore.A.dylib ??? (???) <18098dcf431603fe47ee027a60006c85> /usr/lib/libicucore.A.dylib
0x904bd000 – 0x904f4fff com.apple.SystemConfiguration 1.9.2 (1.9.2) <01426a38ba44efa5d448daef8b3e9941> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x904f5000 – 0x904fefff com.apple.speech.recognition.framework 3.7.24 (3.7.24)/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x904ff000 – 0x904ffffa com.apple.CoreServices 32 (32) <2fcc8f3bd5bbfc000b476cad8e6a3dd2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90500000 – 0x9053afe7 com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9053b000 – 0x90559ff3 com.apple.DirectoryService.Framework 3.5.5 (3.5.5)/System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x9055a000 – 0x905d9ff5 com.apple.SearchKit 1.2.1 (1.2.1) <3140a605db2abf56b237fa156a08b28b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x905da000 – 0x905e1ff7 libCGATS.A.dylib ??? (???) <386dce4b28448fb86e33e06ac466f4d8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x905e2000 – 0x90685ff3 com.apple.QuickTimeImporters.component 7.6 (1290) /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x90686000 – 0x90723fe4 com.apple.CFNetwork 422.15.2 (422.15.2) <80851410a5592b7c3b149b2ff849bcc1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90724000 – 0x9076dfef com.apple.Metadata 10.5.2 (398.25)/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9076e000 – 0x90773fff com.apple.CommonPanels 1.2.4 (85)/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x90774000 – 0x90779fff com.apple.backup.framework 1.0 (1.0) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x9077a000 – 0x90786ffe libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x90787000 – 0x90797ffc com.apple.LangAnalysis 1.6.4 (1.6.4) <8b7831b5f74a950a56cf2d22a2d436f6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x90798000 – 0x90823fff com.apple.framework.IOKit 1.5.1 (???)/System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90824000 – 0x90833fff libsasl2.2.dylib ??? (???)/usr/lib/libsasl2.2.dylib
0x90834000 – 0x9084cff7 com.apple.CoreVideo 1.6.0 (20.0)/System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9084d000 – 0x90881fef com.apple.bom 9.0.1 (136.1.1)/System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x90882000 – 0x9093cfe3 com.apple.CoreServices.OSServices 226.5 (226.5) <25243fd02dc5d4f4cc5780f6b2f6fe26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9093d000 – 0x90fddfff com.apple.CoreGraphics 1.407.2 (???) <3a91d1037afde01d1d8acdf9cd1caa14> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90fde000 – 0x9101dfff com.apple.CoreMediaIOServicesPrivate 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x9101e000 – 0x91090fff com.apple.iLifeMediaBrowser 1.0.11 (212.1.1) /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x91091000 – 0x91091ffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x91092000 – 0x9130dfe7 com.apple.Foundation 6.5.7 (677.22) <8fe77b5d15ecdae1240b4cb604fc6d0b> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9130e000 – 0x922e9ff6 com.apple.QuickTimeComponents.component 7.6 (1290) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x922ea000 – 0x9243cff3 com.apple.audio.toolbox.AudioToolbox 1.5.2 (1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9243d000 – 0x924b7ff8 com.apple.print.framework.PrintCore 5.5.3 (245.3) <222dade7b33b99708b8c09d1303f93fc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x924b8000 – 0x924bffff com.apple.agl 3.0.9 (AGL-3.0.9) <2f39c480cfcee9358a23d61b20a6aa56> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x924c0000 – 0x92cbefef com.apple.AppKit 6.5.6 (949.43)/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x92cbf000 – 0x92e7bff3 com.apple.QuartzComposer 2.1 (106.13) <40f034e8c8fd31c9081f5283dcf22b78> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x92e7c000 – 0x92f45fef com.apple.QuickTimeMPEG4.component 7.6 (1290) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x92f95000 – 0x92fefff7 com.apple.CoreText 2.0.4 (???)/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x930f2000 – 0x931a2fff edu.mit.Kerberos 6.0.12 (6.0.12) <685cc018c133668d0d3ac6a1cb63cff9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x931a3000 – 0x9326efff com.apple.ColorSync 4.5.1 (4.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9326f000 – 0x933a2fff com.apple.CoreFoundation 6.5.5 (476.17) <4a70c8dbb582118e31412c53dc1f407f> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x933a3000 – 0x933a3fff com.apple.Carbon 136 (136) <98a5e3bc0c4fa44bbb09713bb88707fe> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x933a4000 – 0x93484fff libobjc.A.dylib ??? (???) <7b92613fdf804fd9a0a3733a0674c30b> /usr/lib/libobjc.A.dylib
0x93485000 – 0x934e2ffb libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
0x934e3000 – 0x934e3ffe com.apple.quartzframework 1.5 (1.5) <4b8f505e32e4f2d67967a276401f9aaf> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x93574000 – 0x93668ff4 libiconv.2.dylib ??? (???)/usr/lib/libiconv.2.dylib
0x93669000 – 0x93943ff3 com.apple.CoreServices.CarbonCore 786.11 (786.11)/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x93944000 – 0x93aabff3 libSystem.B.dylib ??? (???)/usr/lib/libSystem.B.dylib
0x93aac000 – 0x93b29fef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x93b2a000 – 0x93e4ffe2 com.apple.QuickTime 7.6.0 (1290)/System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x93e50000 – 0x93e6bffb libPng.dylib ??? (???) <4780e979d35aa5ec2cea22678836cea5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x93e6c000 – 0x93ed2ffb com.apple.ISSupport 1.7 (38.2) /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
0x93ed3000 – 0x93f2fff7 com.apple.htmlrendering 68 (1.1.3)/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x93f30000 – 0x93f32ff5 libRadiance.dylib ??? (???) <8a844202fcd65662bb9ab25f08c45a62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x93f33000 – 0x93f33ffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x93f34000 – 0x93f58feb libssl.0.9.7.dylib ??? (???)/usr/lib/libssl.0.9.7.dylib
0x93f65000 – 0x93f97fff com.apple.LDAPFramework 1.4.5 (110) <648b3ee893db8af0a5bbbe857ec0bb7d> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x93f98000 – 0x93f9cfff com.apple.CoreMediaAuthoringPrivate 1.6 (1.6) /System/Library/PrivateFrameworks/CoreMediaAuthoringPrivate.framework/Versions/A/CoreMediaAuthoringPrivate
0x93f9d000 – 0x93f9fff1 com.apple.QuickTimeH264.component 7.6 (1290) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x93fa0000 – 0x93fb5ffb com.apple.ImageCapture 5.0.1 (5.0.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x93ff3000 – 0x9401bfff libcups.2.dylib ??? (???) <16bec7c6a004f744804e2281a1b1c094> /usr/lib/libcups.2.dylib
0x9401c000 – 0x9401cffd com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9401d000 – 0x940c4feb com.apple.QD 3.11.54 (???)/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x940c5000 – 0x94158fff com.apple.ink.framework 101.3 (86)/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x94159000 – 0x941e0ff7 libsqlite3.0.dylib ??? (???) <6978bbcca4277d6ae9f042beff643f7d> /usr/lib/libsqlite3.0.dylib
0x941e6000 – 0x941eafff libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x941eb000 – 0x9429dffb libcrypto.0.9.7.dylib ??? (???) <69bc2457aa23f12fa7d052601d48fa29> /usr/lib/libcrypto.0.9.7.dylib
0x948ef000 – 0x948efffe com.apple.MonitorPanelFramework 1.2.0 (1.2.0)/System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x948f0000 – 0x94932fef com.apple.NavigationServices 3.5.2 (163)/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x94933000 – 0x94e04f3e libGLProgrammability.dylib ??? (???) <5d283543ac844e7c6fa3440ac56cd265> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x94e05000 – 0x94e0cfe9 libgcc_s.1.dylib ??? (???)/usr/lib/libgcc_s.1.dylib
0x94e0d000 – 0x94f8cfff com.apple.AddressBook.framework 4.1.1 (699) <60ddae72a1df8ddbc5c53df92f372b76> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x94f8d000 – 0x94f8ffff com.apple.securityhi 3.0 (30817) <2b2854123fed609d1820d2779e2e0963> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x94f90000 – 0x94fbdfeb libvDSP.dylib ??? (???)/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x94fbe000 – 0x9535bfef com.apple.QuartzCore 1.5.7 (1.5.7) <2fed2dd7565c84a0f0c608d41d4d172c> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9535c000 – 0x95368fff libbz2.1.0.dylib ??? (???) <9ea4fe135c9e52bd0590eec12c738e82> /usr/lib/libbz2.1.0.dylib
0x95369000 – 0x95727fea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x95740000 – 0x95886ff7 com.apple.ImageIO.framework 2.0.4 (2.0.4) <6a6623d3d1a7292b5c3763dcd108b55f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x95887000 – 0x958a6ffa libJPEG.dylib ??? (???)/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x958a7000 – 0x95988ff7 libxml2.2.dylib ??? (???)/usr/lib/libxml2.2.dylib
0x95989000 – 0x959e2ff7 libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x959e3000 – 0x95b1bfe7 com.apple.imageKit 1.0.2 (1.0) <2e354566521df8b1e3a78e9aeab5e6b4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x95b26000 – 0x95b2cfff com.apple.print.framework.Print 218.0.2 (220.1) <8bf7ef71216376d12fcd5ec17e43742c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x95b2d000 – 0x95be4ff3 com.apple.QTKit 7.6 (1290) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x95bf7000 – 0x95c36fef libTIFF.dylib ??? (???) <3589442575ac77746ae99ecf724f5f87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x95cf5000 – 0x95cf6ffc libffi.dylib ??? (???)/usr/lib/libffi.dylib
0x95cf7000 – 0x95d38fe7 libRIP.A.dylib ??? (???) <5d0b5af7992e14de017f9a9c7cb05960> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x95d39000 – 0x95d39ff8 com.apple.Cocoa 6.5 (???)/System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x95d3a000 – 0x95d3affd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x95d3b000 – 0x95d40fff com.apple.DisplayServicesFW 2.0.2 (2.0.2) <97878a73074e7da4fe31ea010a5d5ae1> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x95d41000 – 0x95e08ff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x95e09000 – 0x95e14fe7 libCSync.A.dylib ??? (???)/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x95e15000 – 0x95e22fe7 com.apple.opengl 1.5.9 (1.5.9) <7e5048a2677b41098c84045305f42f7f> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x95e23000 – 0x96233fef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x96234000 – 0x962b1feb com.apple.audio.CoreAudio 3.1.1 (3.1.1)/System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x962b2000 – 0x96380ff3 com.apple.JavaScriptCore 5525.18 (5525.18) <672d1c7f16a4300addabeff4830f5024> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x96381000 – 0x963a5fff libxslt.1.dylib ??? (???) <0a9778d6368ae668826f446878deb99b> /usr/lib/libxslt.1.dylib
0x963a6000 – 0x963ceff7 com.apple.shortcut 1 (1.0) <057783867138902b52bc0941fedb74d1> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x963cf000 – 0x9641efff com.apple.QuickLookUIFramework 1.3.1 (170.9) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x96688000 – 0x966a5ff7 com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x966a6000 – 0x966aefff com.apple.DiskArbitration 2.2.1 (2.2.1) <75b0c8d8940a8a27816961dddcac8e0f> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x966af000 – 0x966afffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x966b0000 – 0x966bcff9 com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x966bd000 – 0x9670eff7 com.apple.HIServices 1.7.0 (???) <01b690d1f376e400ac873105533e39eb> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x96714000 – 0x9673ffe7 libauto.dylib ??? (???) <42d8422dc23a18071869fdf7b5d8fab5> /usr/lib/libauto.dylib
0x96740000 – 0x96769fff com.apple.CoreMediaPrivate 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x96770000 – 0x96803ff3 com.apple.ApplicationServices.ATS 3.4 (???) <8c51de0ec3deaef416578cd59df38754> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x96804000 – 0x96835ffb com.apple.quartzfilters 1.5.0 (1.5.0) <22581f8fe9dd2cb261f97a897407ec3e> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x96836000 – 0x96854fff libresolv.9.dylib ??? (???)/usr/lib/libresolv.9.dylib
0x96855000 – 0x96b5dfff com.apple.HIToolbox 1.5.4 (???) <3747086ba21ee419708a5cab946c8ba6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x96b5e000 – 0x96beaff7 com.apple.LaunchServices 290.3 (290.3) <6f9629f4ed1ba3bb313548e6838b2888> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x96beb000 – 0x96bfaffe com.apple.DSObjCWrappers.Framework 1.3 (1.3) <98f7b46a9f1a099f77e1092ef8e29c63> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x96cdd000 – 0x96ce7feb com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x96e4a000 – 0x96e4aff8 com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x96e4b000 – 0x96ed5fef com.apple.DesktopServices 1.4.7 (1.4.7) <7898a0f2a46fc7d8887b041bc23e3811> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x96f09000 – 0x96f19fff com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <5171726062da2bd3c6b8b58486c7777a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x96f37000 – 0x96f4dfff com.apple.DictionaryServices 1.0.0 (1.0.0)/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x96f4e000 – 0x970cefef com.apple.CoreAUC 3.02.0 (3.02.0)/System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x970d2000 – 0x970eafff com.apple.openscripting 1.2.8 (???) <572c7452d7e740e8948a5ad07a99602b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x970eb000 – 0x97129ff7 libGLImage.dylib ??? (???) <1123b8a48bcbe9cc7aa8dd8e1a214a66> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9712a000 – 0x97131ffe libbsm.dylib ??? (???)/usr/lib/libbsm.dylib
0x97132000 – 0x97140ffd libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x97141000 – 0x97144fff com.apple.help 1.1 (36)/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x97145000 – 0x97174fe3 com.apple.AE 402.3 (402.3) <4cb9ef65cf116d6dd424f0ce98c2d015> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x97175000 – 0x97179fff libGIF.dylib ??? (???) <572a32e46e33be1ec041c5ef5b0341ae> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9717a000 – 0x9725fff3 com.apple.CoreData 100.1 (186) <8e28162ef2288692615b52acc01f8b54> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0xb858d000 – 0xb8592ff3 libCGXCoreImage.A.dylib ??? (???) <375e0cdb64b043378dbf637992bbfeb0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0xb9e4d000 – 0xb9eb2fef com.apple.AppleVAH264HW.component 1.0 (1.0) <49e6103f4d0f364517a5c37bd29b08d7> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0xfffe8000 – 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 – 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
