Activity Forums Blackmagic Design Final Cut Crashes with Backmagic HD Extreme
  • Final Cut Crashes with Backmagic HD Extreme
    Posted by Doug Suiter on June 26, 2006 at 11:13 am
    Hi – I am reposting this for someone else hoping someone here might be able to help – Thanks 🙂
    G’Day,
    First I had problems with the output on the TV monitor, which turned Black and white and then some audio problems (output)… so the obvious solution was uninstall the drivers and re-install the drivers… which I did….
    Now- Final cut not working on black magic presets…works perfectly on DV Pal settings, and when the setting is changed to BackMagic 8 bit…there goes FCP, just Hangs!!!!
    So, any idea how to handle this wonderful problem ???
    – truely
    Gothh
    http://www.sydneyfcp.info
    Kristian Lam replied 20 years, 3 months ago 2 Members · 1 Reply
  • Kristian Lam
    June 27, 2006 at 8:00 am
    Hi Doug,
    This is for Gautam, right? It’s likely a bad PCI slot from our initial investigations via email. However, we’re still working through some connection issues.
    regards
    Kristian Lam
    Blackmagic Design
