Activity Forums Apple Final Cut Pro Legacy Final Cut Crashes Every Time I Render This Project!
  • Final Cut Crashes Every Time I Render This Project!
    Posted by Joseph Wilkins on July 21, 2009 at 5:19 pm
    So I have a 10 minute sequence with a whole bunch of footage of different sources and codecs.
    I created a standard NTSC timeline and created my project.
    Now when I export, it gets about half way through, then QT crashes…
    I took it from one computer to another and got the same result… I even copied all the footage from a firewire drive to my internal… same issue.
    Running the fastest Mac Pro money can buy… the new 8 core with 12 gig of ram.
    FCP 6.0.5 – OSX 10.5.5
    PLEASE>.. client coming in 2 hours… HELP!!
    Alec Gitelman replied 17 years, 2 months ago 4 Members · 5 Replies
  • Steve Eisen
    July 21, 2009 at 5:41 pm
    Sounds like a corrupt file.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Joseph Wilkins
    July 21, 2009 at 5:43 pm
    How do I identify which file is corrupt? I have dozens of files in the sequence.
    Also if it was corrupt, wouldnt I have problems editing it? I have no such problems… only when I export
  • Steve Eisen
    July 21, 2009 at 5:47 pm
    It is a process of elimination.
    Corrupt clips can be tricky. You say you you are using clips from many sources and codecs, my guess is one or more of those clips is not happy with FCP.
    Steve Eisen
    Board of Directors
  • Rafael Amador
    July 21, 2009 at 5:58 pm
    I agree with Steve. Can be a clip or affect applied that is causing the crash.
    Render selecting few clips at a time. You will find out where is the problem.
    rafael
    http://www.nagavideo.com
  • Alec Gitelman
    July 22, 2009 at 5:36 pm
    Check if you have any MPEG2 files in your sequence. (Or any MPEG for that matter) Could be footage from a DVD. That, in my experience, is the most common cause for crashing on render/export, though it could be any corrupt file.
    If you have MPEG files, convert them in MPEG Streamclip prior to using them in your sequence.
