Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Crash upon project load.
  • Final Cut Crash upon project load.
    Posted by Amir Rakib on February 23, 2011 at 12:09 am
    Hi.
    I’ve been given an edited project to colorcorrect, but I can’t seem to open it.
    My Final Cut Pro seems to work just fine with any other project file I have. It loads, saves, and I can edit.
    I’ve already tried trashing my preference files and this particular project opens in other peoples computers.
    When I open the projectfile FCP starts opening, loading, and then crashes. No error, just tells me its quit unexpectedly.
    The same happens when FCP is already opened and I File>Open the project.
    Has this happened to anyone?
    Are there any tricks that you can suggest I try?
    I would really appreciate the help, I’m freaking out. :-\
    Amir Rakib replied 15 years, 7 months ago 3 Members · 3 Replies
  • Steve Eisen
    February 23, 2011 at 1:18 am
    Sounds like a corrupt clip.
    FCS maintenance from digital rebellion may be able to fix the clip. It’s not free.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Gary Askham
    February 23, 2011 at 1:23 am
    An easy way to find out if it is a corrupt clip is to load the project without any media connected (easily done if your media is on a removable drive).
    All the media will be offline but it will let you know if it’s the media or the project. If it’s a corrupt clip then I’d recommend using the trusted “divide and conquer” technique.
    FCP and Avid Technical Support
    Air Post Production
    Shoreditch – London
  • Amir Rakib
    Even if the same file is able to be opened by other computers?
