Activity › Forums › Apple Final Cut Pro Legacy › Final Cut corrupts projects?
  • Final Cut corrupts projects?
    Posted by Dick Avery on August 15, 2013 at 6:58 pm
    Hello, everyone! I desperately need a solution to one problem, so any help would be appreciated.
    I got a project and its backups. Video 1080p/25fps. Audio 48/16. All audio files were converted to 48/16 before import to Final Cut. Sequence settings and easy setup are matched to clips on timeline, so there were no audio drifts. Untill today, when i opened a project and all audio suddenly became out of sync. i opened backups, same thing. Once again, it didnt happen before. But suddenly all projects that i open in final cut becomes corrupted. Some audio clips out of sync radically, some in sync. It seems randomly and i cant find any pattern.
    Modifying exported xml and importing back doesnt do the trick, because in xml everything set to 25fps/ntsc-false.
    Deleting render files and render again doesnt help either.
    Where should i start to troubleshoot the problem?
    Thank you!
    Dick Avery replied 13 years, 1 month ago 3 Members · 4 Replies
  • Massimo Alberto croce
    August 15, 2013 at 8:39 pm
    try deleting FCP preference. It’s a strange behavior.
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Dick Avery
    August 16, 2013 at 8:07 am
    Thanks for reply. I deleted preferences, but it doesnt help. Same thing.
  • Rainer Wirth
    August 16, 2013 at 6:31 pm
    Digital Rebellion is your tool. It’s worth buying. It’s also good for a lot of other things.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Dick Avery
    August 17, 2013 at 9:04 am
    i tried digital rebellion utilities, trashed preferences, removed final cut and all its preferences and renders, reinstall, noting helps. same thing. everytime i open a project or its backups, there are a lot out of sync audio clips. But a couple of days ago those projects opened correctly and there were no out of sync issues.
