Activity Forums Apple Final Cut Pro Legacy Final Cut Conversion: Shooting on PD-170 or HDV matching to 24P Advanced footage
  • Final Cut Conversion: Shooting on PD-170 or HDV matching to 24P Advanced footage
    Posted by Sprocket Size on August 22, 2006 at 7:12 pm
    Hi… We have a videographer in South Africa shooting some Broll for us and she gave us an option of a Sony HDV or a PD-170. The deck we’re using to capture footage is a Sony DVCam deck. Most of the project was shot on Panasonic DVX-100B in 24P Advanced. So.. the question is what camera’s tapes and frame rate would best integrate with the footage we already have….
    Thanks so much for your help.
    Kate
    Rsieben replied 20 years, 1 month ago 4 Members · 6 Replies
  • Dndobson
    August 22, 2006 at 7:47 pm
    Wow, some choice, since Neither Camera does 24P (advanced or standard.)
    But since the 170 has been around longer and I’ve read the HDV camera doesn’t offer any improvement in the DVCAM world, go with which ever camera the shooter feels more comfortable with.
  • Sprocket Size
    August 22, 2006 at 8:11 pm
    Thanks for responding. So… I’ll be able to load the HDV tapes from a DV-Cam deck and won’t need to worry about conversion in FCP? I read somewhere that people were having problems with getting 16×9 from the HDV and that it would auto-convert to 4×3… Is this a myth.
    Thanks so much.
    Kate
  • John Davidson
    August 22, 2006 at 9:41 pm
    We did a live show with 3 vx100’s and one Sony z1u in it’s cineframe mode (picture profile 4).
    Here’s a link to a BTS of the event.
    https://www.magicfeatherinc.com/Kelly/bts.htm
    95% of these shots are on VX100’s, but there are a few wider shots (where people are on stage during the event and the camera is centered – I think the first shot is where people are dancing). The HDV shots are quick in this BTS, but I think it’s a good example of how closely you can match the camera footage.
    We actually digitized the footage in as DVCam, though we shot it in HDV. You will need a sony hdv deck if you shot with hdv because standard DV decks won’t play hdv tapes.
    Our biggest butt pain was the color correct. That was more an issue with the constantly changing lighting during the show than with the footage format. I know I’ll probably get screamed at for this, but we found it’s easier to shoot at the PP4 setting (the Z1u’s Cineframe Film look mode) and match to the VX100’s simulated 24p that way. it really looked cool. Alot of folks really get upset by that format though.
    Let the public castigation begin.
  • John Davidson
    August 22, 2006 at 10:08 pm
    I just noticed the South Africa part – PAL changes the landscape a bit. If you shoot HDV Pal, I don’t think you have to use the Picture Profile 4 Cineframe mode on HDV.
  • Sprocket Size
    August 23, 2006 at 12:49 am
    Thanks for all the advice!
    So you can’t use an HDV tape in a DV-Cam deck. Is that right?
    Kate
  • Rsieben
    August 23, 2006 at 3:43 pm
    No…you can not play HDV footage in a DVCam deck. The new Sony HDV decks are pretty solid machines and are priced very reasonably, IMHO. They will play and record HDV, DVCam and DV tapes and are PAL/NTSC switchable. Another benefit is they will do real time HDV to DVCam or DV down conversion.
    Ric
