Activity Forums Apple Final Cut Pro Legacy Final Cut Capture problems
  • Final Cut Capture problems
    Posted by Mark David spencer on June 10, 2007 at 2:43 pm
    I have a 15″ powerbook 1.25 with 1ghz of RAM running 10.4.9 and Final Cut Pro 5.1.4. Every time I try to capture to my powerbook it won’t capture for more than a minute or so without acting like the timecode has broken.
    I know it’s not the camera because it captures fine on other computers. The firewire works fine on my other computer as well.
    Does anybody know what’s going on with this thing?
    -Mark-
    Jerry Hofmann replied 19 years, 3 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    June 10, 2007 at 2:49 pm
    It’s likely that you’re problem stems from either trying to capture directly to your startup disk in the laptop, or you are sharing the same firewire bus with a drive and your camera. The fix is usually to setup another FW bus by buying a PCI card for the purpose.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mark David spencer
    June 10, 2007 at 2:57 pm
    thanks for the quick reply! Do you have any idea of what might be a good one to look into?
  • Jerry Hofmann
    June 11, 2007 at 1:55 am
    I’m enamored with eSATA setups… they cost about the same as firewire drives, but are a lot faster. Cal Digit, Weibetech, and G-Tech all make them. If you go for the eSata, you’ll need a PCI card to add the port to your laptop. But you should probably add a card too if you go with a FireWire external drive so that the bus isn’t shared with the camera/deck and the drive.
    If you google eSATA adapter, you’ll find what you need. Cal Digit and Weibetech both sell the adapters I think.
    https://www.caldigit.com
    https://www.weibetech.com
    https://www.g-technology.com
    Jerry
